Pic to relay
Results 1 to 5 of 5
Thread: Pic to relay
    Nov 2007
    oxfordshire uk
    A logic level FET is a nice solution, only one component needed. Use an N-channel device, source goes to ground, gate to the output pin of the PIC, drain to the relay coil. Other side of relay coil to +5v. Be sure to connect a diode across the relay coil to deal with bach EMF, or you will destroy thr FET the first time you switch off.
    If you do not need the isolation of a relay, power FET' s will handle a lot of current- tens of amps is common.
    Best of luck!
    Last edited by spuffock; - 7th November 2007 at 11:29. Reason: Forgot I don't use relays much.
    I have tryed it and it works more than fine !
    thanks to all !
  1. PIC to Relay
    By Kalind in forum Schematics
    Last Post: - 24th January 2009, 02:53
  2. HELP ME, SMS controlled relay using PIC
    By pazko1125 in forum mel PIC BASIC
    Last Post: - 2nd October 2008, 16:26
  3. Serial Relays
    By tazntex in forum General
    Last Post: - 17th May 2007, 18:42
  4. Replies: 22
    Last Post: - 9th April 2007, 16:25
