Replace a potentiometer by a digital pot
Results 1 to 9 of 9
    SWITZERLAND (french speaking)
    Default Replace a potentiometer by a digital pot
    Hello,
    I'm trying to control a voltage regulator via a Digital-Pot ("DP" hereunder, it's a DS1804-010 / 10k - 100 steps model).
    <img src="http://home.citycable.ch/flotulopex/downloads/Adj-VR_Num-pot.jpg">
    I replaced the 4k7 pot by the DP and nothing happens (= voltage doesn't vary). Just as if the DP wouldn't increment/decrement anymore.
    The DP is working well as long as I don't connect it to the VR.
    Any idea what's wrong here?
    Roger
    Post
    Bonjour Roger,
    Excerpt of the datasheet ...
    << H - High-Terminal Potentiometer. This is the high terminal of the potentiometer. It is not required that
    this terminal be connected to a potential greater than the L-terminal. Voltage applied to the H-terminal
    cannot exceed the power-supply voltage, VCC, or go below ground.
    L - Low-Terminal Potentiometer. This is the low terminal of the potentiometer. It is not required that this
    terminal be connected to a potential less than the H-terminal. Voltage applied to the L-terminal cannot
    W - Wiper of the Potentiometer. This pin is the wiper of the potentiometer. Its position on the resistor
    array is controlled by the three-terminal control port. Voltage applied to the wiper cannot exceed the
    power-supply voltage, VCC, or go below ground >>
    as the max DS1804 supply voltage is ....
    Bouhou ,snifffff ... goodbye precious chip ! ... if you insist too much !!!
    Try the AD 7376 ...
    Italy
    Hi Roger,
    PWM controlled LM317, output voltage 0V to 6V. (Yes, really 0V!)
    The PWM signal is generated by the microcontroller and the output
    voltage is monitored by the ADC of the microcontroller.
    Best regards,
    Luciano
    (Click to enlarge).
    Wink
    Hi, Roger
    another excerpt ... from the 317 datasheet ...
    Smells the R-2R ladder ... don't you think !
    with a full port ... 256 steps : no so bad !
    ...snif et m.... encore raté!
    Thanks Alain, I've seen this info but, unlike in the shema of my first post, the High end is "open" (not connected) and I thought this would be okay this way.
    Okay then, so how should I control the voltage regulator if not with my DS1804?
    The AD7376 is another option, yes.
    And yes, I've tried to control the LM317 with R+Tr already but you fully loose in ouput voltage precision.
    Is there a other way to do?
    Roger
    Alain,
    How would you make a 256 resistors ladder with 8 ports?
    Any example?
    Roger
    Is it correct to say that this is a Digital-To-Analog converter?
    Roger
    That is correct. This is exactly what it does.
  1. Digital Pot
    Last Post: - 3rd January 2012, 08:54
  2. Controlling a MCP4162 Digital Pot
    By SOTASOTA in forum mel PIC BASIC Pro
    Last Post: - 6th February 2011, 19:51
  3. Digital Pot Advice
    Last Post: - 22nd October 2007, 21:38
  4. Replies: 4
    Last Post: - 24th January 2007, 23:20
  5. Serial control of a digital pot?
    By TonyA in forum mel PIC BASIC Pro
    Last Post: - 3rd June 2006, 00:49
