PIC18F4525 & LCD problem - external resonator ?
Results 1 to 8 of 8
    Nov 2007
    Can you post a schematic of you hook up or give a pin to pin description?
    In you other thread you mentioned using four wires, well it does take four wires for the data but two more for "control".
    You do not need an external OSC to use a LCD, but the configuration will need to be correct.
    Hi Mackrackit,
    Here is the pin to pin description of my schematic:
    PIC 18F4525 ------ LCD HD44780 (16X2)
    B0-------- Pin4 -RS
    B1-------- Pin6- Enable
    B4-------- Pin11- D4
    B5-------- Pin12- D5
    B6-------- Pin13- D6
    B7-------- Pin14- D7
    LCD Pin3- connected to a 20K pot for contrast. The screen still shows black boxes !!!
    LCD Pin5- R/W is connected to ground.
    PIC Pin1- MCLR is not connected to anything. Is this a problem ?
    Here is the code I am using:
    DEFINE OSC 8
    '******Setting up the LCD display******
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 1
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    DEFINE LCD_DATAUS 50
    @_CONFIG_CONFIG1H_OSC_INTIO67_1H
    TRISB=0 'Set Port B as output
    PAUSE 1000
    LCDOUT $FE, 1
    LCDOUT "PIC - LCD Test "
    LCDOUT $FE, $C0
    STOP
    Please Help !!!
    Check the data sheet for this PIC. Several PORTB pins are analog intputs at power-up, and
    you'll need to write to OSCCON to configure it for 8MHz internal.
    The default value in OSCCON at reset is for 1MHz.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Nov 2007
    I have defined Port B as output port in my code by using TRISB=0.
    And by using the command:
    the internal oscillator is working fine at 8 MHz.
    The LCD is now displaying text messages, but when I try to display a numerical value of a variable or a constant, it doesnt show anythin as the screen remains blank.
    Please Help !!
    DEFINE OSC 8
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EBIT 1
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    PAUSE 1000
    LCDOUT $FE, 1
    LCDOUT $FE, $C0
    STOP
    Sep 2006
    Mexico
    Hello, you need to use DEC command, for example:
    b0 var byte
    b0=100
    loop:
    LCDOut $fe, 1
    LCDOut "LCD TEST" 'Display line1
    LCDOut $fe, $c0 'Move to line 2
    LCDOut Dec b0 'Display b0 on LCD
    Pause 500 'Wait .5 second
    goto loop
    OK. Sorry. You're probably right, but give this a shot just for the heck of it.;o}
    1. Edit your 18F4525.INC file in your PBP directory. Change this line;
    __CONFIG _CONFIG1H, _OSC_XT_1H
    to this; __CONFIG _CONFIG1H, _OSC_INTIO67_1H
    Save the file.
    Note this line: __CONFIG _CONFIG3H, _PBADEN_OFF_3H saves you from having to
    manually disable A/D for several PORTB pins. Just FYI.
    2. Change your code to something like this;
    DEFINE OSC 8
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSBIT 0
    DEFINE LCD_EBIT 1
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    '@_CONFIG_CONFIG1H_OSC_INTIO67_1H ; this does nothing & it is not a command
    OSCCON = %01110010
    a VAR BYTE
    Loop:
      LCDOUT $FE,1,"PIC - LCD Test "
      PAUSE 1000
      FOR a = 0 TO 255
       LCDOUT $FE, $C0," A = ", #a
       PAUSE 1000
      NEXT a
      GOTO Loop
    Does it work now?
    -Bruce
    tech at rentron.com
  1. LCD problem with 16F628
    Last Post: - 19th September 2016, 08:28
  2. Newbie? Problem with LCD
    By lew247 in forum mel PIC BASIC Pro
    Last Post: - 7th December 2009, 19:48
  3. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 11:43
  4. Migrating from PIC16F690 to PIC18F4525 and having LCD issues
    By jblackann in forum mel PIC BASIC Pro
    Last Post: - 6th June 2008, 20:05
  5. PIC18F4525 & LCD simple code problem
    By aggie007 in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2007, 16:29
