output doesn't stay high
Results 1 to 8 of 8
    Oct 2007
    Default output doesn't stay high
    Here's a simple line code:
    high 0
    The output will only stay on for about 5 seconds on the 12f629 and 12f675. Then it will go low and doesn't respond. However the same code works fine on the 12f683.
    Is this a limitation of the chip type? Is there a specific code I have to put in for it to sustain a high output?
    (Input voltage = 5VDC from 7805 regulator)
    Thanks.
    Try
    HIGH GPIO.X
    X being the pin number.
    Oct 2007
    I tried this test:
    TRISIO = %000000
    TimeDelay CON 500
    BlinkLoop:
    GPIO = %111111
    Pause TimeDelay
    GPIO= %000000
    Pause TimeDelay
    Goto BlinkLoop
    Basically, I am only interested in GPIO.0, GPIO.1 & GPIO.2. On 12f629 & 12f675, sometimes the pins will fire up and start working. Sometimes, I have to flip the switch couple times for it to work. However, it works every time on the 12f683.
    This is all on 2 different breadboards with multiple 12f629 and one 12f675 and one 12f683. I don't think all the chips can be defective.
    Also, when the 629 & 675 chips are not working, if I touch the chip or one of the I/O pins, the output would start working (driving an LED). I am very puzzled since I have only used the 12f683, but decided to buy cheaper 12f629 models since I don't need all the extra feature.
    any more hints? Thanks.
    How are the config fuses set?
    Question
    And what about GPIO.3/MCLR ???
    This is for the 12F675 using internal OSC
    ANSEL=%00000000
    CMCON=7
    LOOP:
    HIGH GPIO.4
    PAUSE 20
    LOW GPIO.4
    PAUSE 95
    GOTO LOOP
    Oct 2007
    for the 629 & 675:
    Oscilator: INTOSC
    Watchdog Timer: Enabled
    Power-Up Timer: Disabled
    MCLR Pin Function: Reset
    Brown-Out Detect: Disabled
    Code: N/P
    Data EEPROM: N/P
    NEVER MIND!!!!
    Thanks. As I type in this message, I see that the MCLR Pin is for Reset. I changed it and reprogram and it works fine.
    Thanks again for the help. I am the idiot of the day.
    P.S. How come the 12f683 does not exhibit this problem? Does it have a built-in pull-up/down resistor?
    All 3 of these have analog features on GPIO pins, so you'll want to disable analog for each
    pin you want to use for digital output.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. RS485 bus - starting probem
    By wurm in forum mel PIC BASIC Pro
    Last Post: - 27th January 2010, 13:35
  2. SERIN MIDI out of Synch?
    By jncortes in forum mel PIC BASIC Pro
    Last Post: - 9th June 2009, 20:08
  3. Old and beyond help ?
    Last Post: - 11th December 2008, 15:23
  4. Serious Serial Situation Setbacks...
    Last Post: - 7th February 2007, 03:46
  5. sample code for M25P32
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 9th January 2007, 02:37
