PIC18F4525 & LCD simple code problem
Results 1 to 8 of 8
    Mentor, Ohio
    Smile
    Hi Aggie,
    There are more than enough posts on this forum that will help you work your way through just about anything you can think of. I'm not trying to chase you away but if you use the search facility on this forum you should have plenty of reading material that will get you going in no time. In fact I think there's almost enough here to write a book. What an idea!!!!! "USING PIC's WITH LCD DISPLAY". What an idea!!!!!
    HTH,
    BobK
    Nov 2007
    I tried all those things mentioned above - 20K pot for contrast, etc, etc.
    But it still doesnt work !!
    The LCD lights up...but doesn't display anything. The PIC is working fine by itself, I tested it. But its not communicating with the LCD. I think the problem has something to do with the clock/oscillator.
    Do I need to connect an external resonator (20MHz) to the two OSC pins of the PIC ? If so, how do I do it ? Do I need to add something to my code ? How ?
    Please help.
  1. Problem with PIC18F458 ADC code
    By minmin in forum mel PIC BASIC Pro
    Last Post: - 1st June 2011, 08:13
  2. Strange LCD problem with PIC16F876A
    By Glenn in forum mel PIC BASIC Pro
    Last Post: - 15th October 2009, 08:56
  3. Making Program Code Space your playground...
  4. problem with my code
    By civicgundam in forum mel PIC BASIC Pro
    Last Post: - 3rd February 2008, 01:52
  5. Apparent code size problem
    By eetech in forum mel PIC BASIC Pro
    Last Post: - 30th July 2007, 15:51
