MCP23016 I2C serial I/O expander chip
Results 1 to 8 of 8
    Arvada Colorado
    Default MCP23016 I2C serial I/O expander chip
    Hi all,
    Has anyone used the MCP23016 I/O expander with PBP? I can't seem to get the I2CREAD command to return anything. I'm using an 18F87J50. I have my LCD working and diagnostic LED's on my new board are all under control. I can see there is a bit stream on the data line that recurs on schedule. (I execute the I2CREAD command about every 5 seconds.)
    Here is my code:
    define osc 25
    intcon = %10100000
    intcon2 = %01000000
    t0con = %11010101
    rcon = %00000000
    adcon0 = %00010001
    adcon1 = %00001010
    define lcd_dreg portd
    define lcd_dbit 0
    define lcd_rsreg porte
    define lcd_rsbit 0
    define lcd_ereg porte
    define lcd_ebit 1
    low porte.2
    define adc_bits 10
    insin var word
    insin = 0
    Loop:
    lcdout $fe, 1
    lcdout "The lcd is working"
    I2Cread portc.4, portc.3, %01000000, insin, noitwoc
    lcdout $fe, $c0
    lcdout dec insin
    pause 5000
    goto loop:
    noitwoc:
    lcdout $fe, 1
    lcdout "no i2c ack"
    pause 2000
    goto loop
    I have checked the schematic time and time again. It matches the I/O expander data sheet. and the data/clock pins match the code. I have measured the RC clock and it is running correctly. I have only tried the 3.9k and 33pF RC combo. I never get to the noitwoc loop so I ass'u'me I am recieving the acknowledge from the 23016. The 23016 spec sheet states that the chip is default to all inputs. But the variable insin never changes from 0 even if one or all pins are set high or low?
    I am fairly certain that my problem is not hardware.
    Any advice? Oh by the way the SFR's setup here work well with the 18F4525 setup to work with the LAB-X1 experimenter board. Except the dbit is 4 on the X1.
    Joe
    Arvada Colorado
    Arvada Colorado
    Below is modified code.
    After re-reading (tfm) the spec i noticed that the 23016 requires: adress, command,adress (again), data, data,....
    No on reset I get the no i2c ack display and I see on my oscope that there aren't quite enough bits on the data line. Then the next time the loop executes I get all expected bits on the data line, but the last two byte which I expect to be reflective of the I/O pins on the 23016 never change and are always low?
    Here is the full code again:
    INTCON = %10100000 ' Enable TMR0 interrupts
    INTCON2 = %01000000 ' ENABLES PORTB PULL UPS
    T0CON = %11010101 ' ENABLES TM0 AND SET PRESCALER
    RCON = %00000000 ' IPEN RCON.7 INTERUPT PRIORITY LEVEL DISABLED
    ADCON0 = %00010001 ' ATOD CH 4 CONVERTER ENABLED
    ADCON1 = %00001010 ' VSS AND VDD REF LEVELS A0-A4 ANALOG A5-A12 DIG
    'ADCON2 = %10000110 ' RIGHT JUST RESULT 0 TAD FOSC/64
    'define I2C_SCLOUT 1 ' just messing around trying to see if I can get it to work. No change with this line included
    'DEFINE I2C_HOLD 1 ' just messing around trying to see if I can get it to work. No change with this line included
    DEFINE LCD_DREG PORTD ' PortD is the data port
    DEFINE LCD_DBIT 0 ' PORTD.4
    DEFINE LCD_RSREG PORTE ' PortE contains the Reset/Enable port
    DEFINE LCD_RSBIT 0 ' PORTE.0 = reset bit
    DEFINE LCD_EREG PORTE ' PortE contains the Reset/Enable port
    DEFINE LCD_EBIT 1 ' PORTE.1 = ENABLE BIT
    Low PORTE.2 ' LCD R/W line low (W)
    Pause 500 ' Wait for LCD to start up
    DEFINE ADC_BITS 10 ' Set number of bits in result
    INSin var word
    insin = 0
    addr var byte
    addr = 0
    'i2cwrite portc.4, portc.3, %01000000, insin, noitwoc
    LOOP:
    i2cWRITE portc.4, portc.3, %01000001, $00, %01000001, insin, noitwoc
    pause 10
    LCDOUT $FE, 1
    lcdout "IM ALIVE"
    lcdout $fe, $c0
    lcdout dec insin
    'output porte.6
    HIGH PORTJ.1
    pause 250
    low PORTJ.1
    HIGH PORTJ.0
    PAUSE 250
    LOW PORTJ.0
    HIGH PORTJ.2
    PAUSE 250
    LOW PORTJ.2
    HIGH PORTJ.3
    PAUSE 250
    LOW PORTJ.3
    HIGH PORTJ.4
    PAUSE 250
    LOW PORTJ.4
    HIGH PORTJ.5
    PAUSE 250
    LOW PORTJ.5
    HIGH PORTJ.6
    PAUSE 250
    LOW PORTJ.6
    HIGH PORTJ.7
    PAUSE 250
    LOW PORTJ.7
    HIGH PORTE.6
    PAUSE 250
    LOW PORTE.6
    HIGH PORTE.7
    PAUSE 250
    LOW PORTE.7
    HIGH PORTE.5
    PAUSE 250
    LOW PORTE.5
    HIGH PORTE.4
    PAUSE 250
    LOW PORTE.4
    HIGH PORTE.3
    PAUSE 250
    LOW PORTE.3
    GOTO LOOP
    noitwoc:
    lcdout $fe, 1
    lcdout "no i2c ack"
    pause 2000
    goto loop
    GeoJoe, Where is your I2CREAD statement?
    Arvada Colorado
    My mistake. I've been changing the code and trying all kinds of different stuff. I had tried the write command just to see what happened and didn't change it back when I posted that reply. However I have the write command in there now. I don't think the clock is correct. It isn't idling high. I am still working on this so if anyone has any wisdom to share please do. This is a really sweet chip set, the pic has a bunch of i/o's, on board USB and huge instruction memory space of 128k; the i/o expanders add an extra 16 gpio's each. I have 3 on my board. This left the other pic pins open for things like wireless modem, a maxstream zigbee module, LCD, and left many of the ATOD's open.
    Any advice on this???????????
    Arvada Colorado
    read command that is.
  1. I2C Master/Slave 16F88/16F767 working code
    Last Post: - 23rd October 2012, 23:31
  2. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  3. MCP23016 I/O expander
    By Demon in forum mel PIC BASIC Pro
    Last Post: - 24th October 2005, 02:01
  4. MCP23016 I/O expander with PBP?
    By Jon Chandler in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2005, 10:32
  5. I2C I/O Expander PCF8574 hanging?
    By NavMicroSystems in forum Serial
    Last Post: - 4th August 2005, 03:26
