18F4620 HPWM Half Bridge Mod problem
Results 1 to 9 of 9
    May 2007
    I was fighting with a 18F4550 and it's 4 multiplexed PWM's (P1-P4). I had no time to study about it. My timeless and fast solution was I just used an ordinary pwm PIC (16F628a) and a (fast) 4052 multiplexer and forgot about enhanced pwm stuff for a 1/256th microstepper unipolar stepper motor controller I made. Also used a SN754410NE bridge.
    Cheap, fast & easy...
    (The 18F4550 i left it for another USB proyect)
    RodSTAR
    Aug 2007
    Unhappy
    Hi Bruce thank you for reply, It is not working. I think something is wrong or missing for this situation.
    Hi rodstar, that is possible. Deadtime is very important for me. I have to put a deadtime in the PWM signals.
    Is it still only showing a PWM signal on P1A? Are you running this in ISIS or on a real PIC?
    More info would help.
    Edit: I ran this through MPSIM with the logic analyzer on P1A and P1B. Sure looks like it works.
    DEFINE	OSC 20
    Duty VAR WORD ' 5%=25, 95% = 450
    TRISC.2=0
    TRISD.5=0
    T2CON = %00000101  ' Timer2 ON, prescale 1:4
    PR2 = 124          ' 10kHz
    CCP1CON = %10001100' half-bridge with P1A & P1B
    PWM1CON = %10001111' set dead-time
    Loop:
      For Duty = 25 TO 450  ' from 5% to 95% duty
       CCP1CON.4 = Duty.0	' Setup 10-bit duty cycle as
       CCP1CON.5 = Duty.1	' a 10-bit word
       CCPR1L = Duty >> 2
       PAUSEUS 24
      Next
      Goto loop
    Screen capture of MPSIM logic analyzer attached.
    Might be a problem with ISIS or your config settings?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Aug 2007
    Hi Bruce , Thank you for interest.
    The problem is not simulation. I have just tried your code on the proto board. It is not working. I programmed your code. Nothing was changed.
    Did you use some fuse setting that i didn't see in your code. I think something is wrong with this PIC model because my 18F458 and 16f690 and 16f684 is working Half bridge Mod properly in ISIS and proto board.
    Thank you again.
    Here's the config settings I used when running this through MPSIM.
    __CONFIG _CONFIG1H, _OSC_HS_1H
    __CONFIG _CONFIG2H, _WDT_ON_2H & _WDTPS_512_2H
    __CONFIG _CONFIG3H, _PBADEN_OFF_3H
    __CONFIG _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    I have attached the .hex & .bas files I used.
    After looking at one of many errata sheets for the 18F4620, I doubt I'll be in
    any huge hurry to try this one.
    The Rev A silicon Errata sheet shows a boat-load of problems with the ECCP
    module. It could very well be a silicon bug. Good luck...;o}
    -Bruce
    tech at rentron.com
    Aug 2007
    Thank you very much for valuable helps. The last code was the same. I will research more. Maybe one mounth later i will work with other PIC wich have not got big bugs if I can't succeed.
    Best regards.
    Aug 2007
    Angry
    18F458 is working very well with the same code but 18F4620 is not. I think there is a PIC bug.
  1. Using HPWM in half bridge mode on 16f690
    By Chris Barron in forum mel PIC BASIC
    Last Post: - 29th December 2006, 12:18
  2. sound command & music
    By trying in forum mel PIC BASIC Pro
    Last Post: - 26th May 2006, 15:14
  3. 3 HPWM channels
    Last Post: - 4th April 2006, 03:43
  4. HPWM problem .. pls help!
    By Samuel in forum mel PIC BASIC Pro
    Last Post: - 1st February 2006, 16:30
  5. problem ont hpwm on the pic16f767!!
    By oscar in forum mel PIC BASIC Pro
    Last Post: - 20th May 2005, 11:41
