Demo version...
Results 1 to 5 of 5
Thread: Demo version...
    Oct 2007
    Default Demo version...
    Here I am having some doubts about demo version...
    I'll be thankful if you please answer...
    1. Can we use ICD Of different companies on my PIC BASIC or PIC BASIC Pro software...
    2. Can I use Programmers of different companies on my PIC basic pro software...
    3. Where is the compiled hex file stored when we are going to program a basic program...
    Simran..
    1) I don't know...
    2) You can use any programmer you want. The compiler outputs a hexfile. It does not care how that hexfile ends up inside the PIC. If you are using an IDE such as the MicroCodeStudio the programmer needs to be compatible with that if you want to use the Compile & Program feature. Otherwise, compile your program, import the .hex file in your programmer software and program the PIC.
    3) When compiling, the resulting files (.lst .hex etc) ends up in the same folder as your sourcefile(s)
    Don't know if it's any different with the demo-version but I guess not.
    /Henrik Olsson.
    damu's Avatar
    damu Guest
    Default new to pic basic please
    i am new to picbasic i have a code that was for picbasic but it is not running on picbasicpro demo versio please guide me for the same
    ------code---
    symbol porta = 5
    symbol trisa = 133
    symbol portb = 6
    symbol trisb =134
    poke trisa, 255
    poke trisb, 240
    b0 var byte
    start:
    peek portb, b0
    if bit4 = 0 then trigger
    goto start
    trigger:
    peek portb, b0
    if bit5 = 1 then send
    goto start
    send:
    peek porta, b0
    if bit4 = 1 then eleven
    poke portb,b0
    goto start
    eleven:
    if bit0 = 0 then ten
    poke portb,11
    goto start
    ten:
    poke portb,10
    goto start
    please help
    Quote Originally Posted by damu View Post
    i am new to picbasic i have a code that was for picbasic but it is not running on<font color=red> picbasicpro demo versio </font color>please guide me for the same
    ------code---
    symbol porta = 5
    symbol trisa = 133
    symbol portb = 6
    symbol trisb =134
    poke trisa, 255
    poke trisb, 240
    b0 var byte
    start:
    peek portb, b0
    goto start
    trigger:
    peek portb, b0
    goto start
    send:
    peek porta, b0
    poke portb,b0
    goto start
    eleven:
    poke portb,11
    goto start
    ten:
    poke portb,10
    goto start
    please help
    It looks like PBasic not pro, peek and poke are a not recomenended, but still supported method. In the pro version you can control ports directly using the Port and TRIS commands.
    I. E. instead of symbol porta = 5 and symbol trisa = 133 you would write TRISA = 133 or TRISA = %10000101 or TRISA = $85 and PortA = 5 or PortA=$5 or PortA=%00000101, symbol is used to alias a variable but not to create it. This is however the correct thread for PIC basic, but you need to know the pro version is different.
    Almost it, i think it's also caused by Bit0, bit1 etc etc. Below my suggestion
            TRISA = 255
            TRISB = 240
            b0 var byte
    start:
            b0 = PORTB
            if b0.4 = 0 then trigger
            goto start
    trigger:
            b0 = PORTB
            if b0.5 = 1 then send
            goto start
    send:
            b0 = PORTA
            if b0.4 = 1 then eleven
            PORTB = b0
            goto start
    eleven:
            if b0.0 = 0 then ten
            PORTB = 11
            goto start
    ten:
            PORTB = 10
            goto start
  1. New version of Pic BASIC Pro released
    By Demon in forum mel PIC BASIC Pro
    Last Post: - 12th March 2010, 15:41
  2. PicBasic Pro Demo
    By nbrucew in forum mel PIC BASIC Pro
    Last Post: - 26th August 2009, 19:10
  3. 16f887 44 pin demo board code problem?
    Last Post: - 7th December 2008, 14:17
  4. Picbasic Pro Demo assembly errors
    By mikeRho in forum mel PIC BASIC Pro
    Last Post: - 2nd January 2008, 06:41
  5. DT-ints-18 - new version
    By dip1 in forum mel PIC BASIC Pro
    Last Post: - 10th October 2007, 20:09
