I supose this depends on the type of LED. Each type of LED may need its own gamma curve.
Hi Mike,
Fantastic work!
Could you please post:
LED Part number,
Gamma correction routine?
Please, Please, Pretty Please?
I've learned a lot from this thread and want to say Thank You, to ALL who have contributed.
73,
Terry K9HA
Hi Terry, K9HA,
Attached is assembler source with "gamma" table. I also slowed down LED "0" fade loop time considerably to look for "stair stepping" effect since I was only using 64 "gamma" steps but the fading is remarkably smooth.
I'm using Fairchild MV57164 Bar/Dot displays but almost any LED should work fine.
A couple observations;
(1) I'm very surprised at the light produced from LED "10" which is set to a duty cycle of 1 (1-usec -> 1/1280th or 0.078125% duty cycle).
(2) Mirrored BAM doesn't seem to be necessary to correct the 127-128 duty cycle transition visual artifact when using a multiplexed display (with gaps between LED updates).
Regards and "very 73", Mike, K8LH
Mike,
Thank you for the part data AND the assembly code.
It will be fun experimenting with this!
73
Terry
K9HA
I'm geeked!
Just added a 256-step BAM driver to an old project which had a 4-digit 7-segment display (direct I/O drive) and using it for brightness control works great (488-Hz refresh rate @ 4-MHz INTOSC).
I've got a few of these old three or four digit 'pnp' (practically no parts) type projects around and I had always wanted to implement a form of PWM brightness control on them but nothing worked as well or was as 'clean' as this K8LH BAM driver method.
Only "down side" so far is that I haven't figured out a way to implement "cycle accurate" delays in BoostC which means I'm stuck writing in assembler which no one can understand (lol).
Regards, Mike, K8LH
