Bit Angle Modulation (BAM) in a PIC
Results 1 to 40 of 151
    Hi Mike,
    I wholeheartedly agree.
    MIBAM with multiplexed display doesn't seem like it's worth it, because you loose so much of the available dutycycle.
    Thanks for the explanation of the diagonal line.
    I did get your example working, with only 8 leds (2 columns).
    I made enough changes to not know if it's actually the way yours works or not.
    But I don't see a way to incorporate it into the MIBAM routines (because of the duty cycle losses), so I'm officially tossing Charlie out the window.
    Good thing I live at ground level.
    I'll complete the modifications for your previous idea (full port updates) and get this thing done.
    Thanks for all your assistance Mike, much appreciated.
    Aug 2005
    Michigan, USA
    Yes, LED duty cycle is decreased with any multiplexed display and while we normally pump up the "peak" current to get better "average" current (and brightness) we can't do that with a Charlieplexed display (or any other multiplexed display that uses "direct drive" for matrix columns or rows).
    Anyway, I thought you might enjoy taking a peek at a multiplexed 8-channel RGB display demo' (24 discrete LEDs) with 256-level BAM driver and a pretty amazing 868-Hz refresh rate. The display is fashioned as a 3x8 matrix (33% duty cycle) so biasing the LED "peak" current to approximately 3x desired "average" current will be necessary. This assembly language program just contains the driver. No animation or anything like that, yet.
    Regards, Mike
    Aug 2005
    Michigan, USA
    Is there any way I can get temporary access to locked post above to update the program listing? I posted incorrect version which has some bugs. Sorry!
    Aug 2005
    Michigan, USA
    Darrel (and gang),
    A long overdue assembly language Charlieplexed BAM example for 20 LEDs on a 12F683. Example uses 8-bit 256 step BAM driver with a 1-usec step size. Refresh rate is 781-Hz with a 1280-usec frame rate. LED "0" is animated. That is, it ramps from duty cycle value of 0 up to 127 and then back down to 0. LED "10" through LED "19" are lighted with duty cycle values of 1 through 10 so you can check out "low end" illumination.
    You might just hook up a single LED for LED "0" to check out the program. Just connect the LED cathode to GP5 and the LED anode to GP0.
    Kind regards, Mike
    Aug 2005
    Michigan, USA
    Has anyone tried "gamma" correction to smooth out LED brightness level changes? I just added a 64 level rom "gamma" array to the program in the previous post and it made an amazing difference in the smoothness of the fade.
    I supose this depends on the type of LED. Each type of LED may need its own gamma curve.
    Aug 2005
    Michigan, USA
    Bummer! I was afraid of that...
    Aug 2009
    Quote Originally Posted by Mike, K8LH View Post
    yep... tryed it in 3 ways:
    1. Simple ISR-based software PWM with floating (table-generated) pulse widths.
    2. Strobing /OE of external latches (54 PWM channels/PIC16f877a) with HW PWM output (table-generated) + SW PWM (i had to slightly increase LED current to get more brightness, as the full duty cycle hadn't been achievable, almost like with 1.5x charlieplexing)
    3. Increased bit depth to 13(14) bit and PWM speed (refresh rate) to 610Hz on 18F for better perfomance.
    Aug 2009
    Default OFFTOPIC (maybe))
    2 ALL...
    There is one small problem with high speed BAM/MIBAM. Problem exists if u use simpler MOSFET driving scheme (or if u use slower bipolar schemes like darlinghton's transistor pairs and if actual switches are controlled by MCU's outputs directly) or if u need higher current per channel, especially if currents on some channels are significantly different. This happens because switching delays differ too. Check out datasheets for gate driving characteristics for higher current applications and compare it with needed signal discretization. PWM methods don't solve the problem but it need less signal transitions per cycle and work slightly better for lower bit depths without additional gate drivers (for reasonable currents, of course). Actually this problem just increase duty_cycle/brightness relation's non-linearity, but combined with longer wires, bad PCB layouts etc. it may cause unpredictable results for visual perception. So don't be surprised). sorry, can't describe problem in detail because of my poor english (lack of practics) and lazyness. Anyway, best solution is to check your application's requirements in advance))).
  1. decoding quadrature encoders
    By ice in forum mel PIC BASIC Pro
    Last Post: - 28th February 2017, 10:02
  2. Cordic trig assembly code for PIC18f
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 8th September 2015, 06:36
  3. AT/PS2 Keybord - PIC Interface?
    By Kamikaze47 in forum Code Examples
    Last Post: - 9th August 2009, 17:10
  4. MIBAM - (Mirror Imaged Bit Angle Modulation)
    Last Post: - 15th February 2009, 17:02
  5. Bit Angle Modulation
    By BH_epuk in forum mel PIC BASIC Pro
    Last Post: - 18th November 2008, 08:01
