Bit Angle Modulation (BAM) in a PIC - Page 2
Results 41 to 80 of 151
Threaded View
  1. #11
    Aug 2005
    Michigan, USA
    Hi Darrel,
    I think we may be confusing each other with terminology and perhaps a slight difference in our design. I was using "1T" as the PWM step size. For example, if we were to use a step size of 10-usecs and 256 steps or levels then we'd have a 2560-usec period (256*10-usecs). The b0 output is 10-usecs or 1T long. The b1 output is 20-usecs or 2T long but I split it in half with 10-usecs or 1T on either side of the b0 10-usec (1T) output. That's how I get |2T|1T|1T|1T|2T| == |20us|10us|10us|10us|20us| == |half b2|half b1|full b0|half b1|half b2|. I thought this was how you were doing it but now I suspect I didn't look closely enough at your code and I apologize.
    It also seems you think I'm combining the b2, b1, and b0 outputs and reducing resolution but I'm not. I'm simply generating the b2, b1, and b0 outputs during a single interrupt interval.
    More later... I'm trying to see if I can upgrade a very old 12F683 Charlieplexed 5-pin 20-LED project from 64 levels per LED to 256 levels per LED using MIBAM. Wish me luck...
    Kind regards, Mike
    <object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/AgQTBKcg2D4&color1=0xb1b1b1&color2=0xcfcfcf&hl=en& feature=player_embedded&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowScriptAccess" value="always"></param><embed src="http://www.youtube.com/v/AgQTBKcg2D4&color1=0xb1b1b1&color2=0xcfcfcf&hl=en& feature=player_embedded&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="425" height="344"></embed></object>
  1. decoding quadrature encoders
    By ice in forum mel PIC BASIC Pro
    Last Post: - 28th February 2017, 10:02
  2. Cordic trig assembly code for PIC18f
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 8th September 2015, 06:36
  3. AT/PS2 Keybord - PIC Interface?
    By Kamikaze47 in forum Code Examples
    Last Post: - 9th August 2009, 17:10
  4. MIBAM - (Mirror Imaged Bit Angle Modulation)
    Last Post: - 15th February 2009, 17:02
  5. Bit Angle Modulation
    By BH_epuk in forum mel PIC BASIC Pro
    Last Post: - 18th November 2008, 08:01
