Serin vs Serin2
Results 1 to 13 of 13
Thread: Serin vs Serin2
    Jun 2007
    Mansfield, UK
    Default Serin vs Serin2
    Hi, which is the fastest to use, Serin or Serin2? This project needs speed rather than functionality so im wondering if its worth using serin this time
    I do not think there is much of a speed difference between the two.
    Default DEBUG probably fastest
    The handbook says DEBUG is the smallest and fastest serial I/O command.
    Why not try that?
    HTH
    Brian
    Italy
    These are software UARTS using the bit-banging technique.
    The speed is the same because the speed is tied to the baud rate
    you receive the data.
    Best regards,
    Luciano
    Jun 2007
    Mansfield, UK
    ahh. that makes sense. im using 9600N at the moment. how do i know how high i can go? are there chip specific restrictions?
    19200 according to the manual is the top end for SERIN/OUT2. You will need an OSC faster than 4MHz though.
    Look at appendix A
  1. Serin to Serin2 ??
    By Gixxer in forum mel PIC BASIC Pro
    Last Post: - 25th January 2008, 03:56
  2. serin and serin2??? need to understand
    By tkly36 in forum mel PIC BASIC Pro
    Last Post: - 7th April 2006, 05:13
  3. Serin / Serin2 / Debugin Differences
    Last Post: - 19th January 2006, 06:32
  4. SERIN SERIN2 Timeout
    By markedwards in forum mel PIC BASIC Pro
    Last Post: - 23rd June 2005, 18:59
  5. serin and serin2
    By rastan in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2005, 13:10
