Exponential Operator
Results 1 to 12 of 12
    Oct 2007
    Default Exponential Operator
    Hello,
    Is there a math operator in PicBasic Pro for raising one number to the power of another?
    I can't seem to find one.
    I would expect it to be:
    a = 2^4 ' answer is 16
    or EXP()
    or POW()
    but none of these seem to be documented for PBP.
    -Andrew
    Default Maths operators
    Microcontrollers have limited resources and generally are not efficient for floating point or exponential operations. PBP is an integer basic that makes good use of limited devices. You can get integer exponential functions by repeated multiplication and with the new LONG variables on PBPL you can probably get reasonable results by scaling but you will need to devise the functions yourself.
    Working with floating point (in Mikroelktronica or Proton+) or longs with PBPL will devour code space.
    What are you doing that needs exponentials? There may be an alternative solution.
    HTH
    Brian
    Oct 2007
    Default Re: Exponential Operator
    Thank you for confirming my fear.
    I'm using a PIC16F877 to control some MAX7219 LED display chips.
    I'm trying to access 6 different rows of LED's in succession.
    To light up an LED in a column you do this:
    row 1 = %0001
    row 2 = %0010
    row 3 = %0100
    row 4 = %1000
    etc.
    I just wanted to convert between #4 and %1000 with a single line of code.
    Ideally, I wanted to make it a part of the FOR statement in a loop.
    You can see below the code I ended up using instead of the invalid: STEP 2^Row
    PBP code fragment follows:
    Row VAR BYTE
    Light1 VAR WORD
    Column VAR WORD
    FOR Row = 1 to 64 STEP Row*2-row
    Light1 = Column + Row
    LOW Load
    SHIFTOUT DOUT, CLK, 1,[Light1\16] 'send command to LED chip
    HIGH Load
    NEXT Row
    -Andrew
    sinoteq's Avatar
    sinoteq Guest
    Default Not sure but...
    Have you looked at the shift functions >> and << around page 32 in the PBP manual?
    row 1 = %0001
    row 2 = %0010
    row 3 = %0100
    row 4 = %1000
    If you want a byte or word to do the above thing this might work:
    X var Byte
    Y var Byte
    Y=1 'Now Y=%00000001
    For x=0 to 6 Step 1
    Y=Y << 1 'Shift Y left one time, Y=%00000010,Y=%00000100,Y=%00001000
    Next x
    This command is also usefull when combining nibbles and other stuff, shift happily left or right as you see fit.
    Feb 2003
    Salt Lake City, Utah USA
    B0 = DCD 3 ‘ Sets B0 to %00001000
    (see PBP manual for full details)
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Oct 2007
    Default What is PBPL?
    Thank you Sinoteq
    I checked that out.
    I think I can even do this:
    x = 6
    Y=Y << x
    And thank you Paul,
    I'll look into DCD.
    By the way, what is PBPL?
    -Andrew
  1. what is objective of this operator "*/" ?
    By iugmoh in forum mel PIC BASIC Pro
    Last Post: - 17th April 2008, 03:43
  2. Exponential
    By civicgundam in forum General
    Last Post: - 3rd February 2008, 18:19
  3. '*/' operator
    By jblackann in forum mel PIC BASIC Pro
    Last Post: - 18th January 2007, 21:00
  4. math operator LOG
    By Eyal in forum mel PIC BASIC Pro
    Last Post: - 23rd July 2004, 00:45
  5. Log and exponential
    By anj in forum mel PIC BASIC Pro
    Last Post: - 5th March 2004, 21:03
