code size
Results 1 to 7 of 7
Thread: code size
    You have a lot of options.
    If you're using MCS as the editor the bottom screen shows the compiled file size.
    If you use MPASM as the assembler you can open the .LST file and look at the bottom.
    Program Memory Words Used: 63
    Program Memory Words Free: 8129
    With PM as the assembler you can look at the bottom of the .LST file;
    + 003C- 0063 @@0000 sleep
    + 003D- 018A clrf PCLATH
    + 003E- 283C goto @@0000
    Or you could use Darrels' GetAddress macro to find & display the size something like this;
    @ device  pic16F877, xt_osc, wdt_off, lvp_off, protect_off
    DEFINE LOADER_USED 1
    RetAddr VAR WORD
    asm
    GetAddress macro Label, Wout
        CHK?RP Wout
        movlw low Label          ; get low byte
        movwf Wout
        movlw High Label         ; get high byte
        movwf Wout + 1
    endasm
    loop:
        @ GetAddress _Over, _RetAddr
        HSEROUT [HEX4 RetAddr,13,10]
        High 0          ' Turn on LED connected to PORTB.0
        Pause 500       ' Delay for .5 seconds
        Low 0           ' Turn off LED connected to PORTB.0
        Goto loop       ' Go back to loop and blink LED forever
    Over:
    Or you could just open & examine the compiled .HEX file with your device programmer.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    i'm using mpasm assembler and i could find the size of the code at the very bottom. thank you again.
    Goto the directory that you saved your project in. That is where you will find the *.LST file Bruce told you about. If your program is called blinky, you will look for blinky.LST.
    when mpasm compiles my code using PicBasic Pro, does the entire PBPPIC14.lib file get compiled also, or is it only the specific functions that i'm using such as ADCIN, or SEROUT, etc.
    Only sections of the library that are required get compiled.
    -Bruce
    tech at rentron.com
    Sep 2005
    Campbell, CA
    I don't know what your needs are, but I have had two instances where I needed to
    automatically watch the code size:
    1. I use MCLOADER, which occupies some of the chip's upper memory.
    I need to make sure my compiled code does not "run into" the bottom of MCLoader.
    2. I sometimes want to know if my code is small enough to fit into a smaller, cheaper chip.
    The technique I use is to add a few statements at the end of my programs -
    ORG 0x1fcee <=== Put the address you don't want to over-run here.
    nop
    If the code is too big and over-runs the ORG address, MPASM will flag an error.
    Charles Linquist
  1. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  2. Loop with two motor and 2 sensors
  3. Making Program Code Space your playground...
  4. Apparent code size problem
    By eetech in forum mel PIC BASIC Pro
    Last Post: - 30th July 2007, 16:51
  5. pic18F code size problem???
    By dogi in forum mel PIC BASIC Pro
    Last Post: - 7th March 2005, 22:52
