1-wire read ROM with 12F675
Results 1 to 3 of 3
    Oct 2007
    Default 1-wire read ROM with 12F675
    Hello,
    I'm trying to get the serial number from a DS18B20 connected to a 12F675 without any success.
    There is a 4.7K between VCC and DQ.
    Here is the data I get as an output:
    Ser# = 000000000000h
    CRC Value = 00h
    Read ROM...
    Read 64-bit device data into the 8-byte array
    Family code00h
    CRC Value = 00h
    I am sure of the DS18B20 (it is working).
    Here is the code:
    SO CON 0 ' GPIO.0 (Pin7) Serial out
    DQ CON 1 ' GPIO.1 (Pin7) one wire data pin "DQ"
    SEARCH_ROM CON $F0
    ID VAR BYTE[8] ' Array storage variable for 64-bit ROM code
    ANSEL=0
    OUTPUT DQ
    SEROUT2 SO,16468,[13, 10, "1-wire Device Search", 10,13,10,13]
    start:
    SEROUT2 SO,16468,[ "Read ROM...",10,13]
    OWOUT DQ, 1, [$33] ' Issue Read ROM command
    SEROUT2 SO,16468,[ "Read 64-bit device data...",10,13]
    OWIN DQ, 0, [STR ID\8]' Read 64-bit device data into the 8-byte array "ID"
    SEROUT2 SO, 16468,["Family code",HEX2 ID[0],"h", 10, 13]
    SEROUT2 SO, 16468,["Ser# = ",HEX2 ID[1],HEX2 ID[2],HEX2 ID[3],HEX2 ID[4],HEX2 ID[5],HEX2 ID[6],"h", 10,13]
    SEROUT2 SO, 16468,["CRC Value = ",HEX2 ID[7],"h", 10, 13]
    pause 2000
    GOTO start
    Any idea about why it is not working ?
    Fabien
    Jan 2006
    Istanbul
    Put all these at the beginning of your code.
    @ DEVICE pic12F675, INTRC_OSC_NOCLKOUT
    @ DEVICE pic12F675, WDT_ON
    @ DEVICE pic12F675, PWRT_ON
    @ DEVICE pic12F675, MCLR_OFF
    @ DEVICE pic12F675, BOD_OFF
    @ DEVICE pic12F675, CPD_OFF
    @ DEVICE pic12F675, PROTECT_OFF
    DEFINE OSCCAL_1K    1   ' osc calibration
    CMCON = 7               ' Disable comparators.
    VRCON.7 = 0             ' Disable voltage reference module ; no current.
    TRISIO = %000000        ' All output except for GP3.
    ADCON0.0 = 0            ' Turn off ADC module.
    ANSEL = 0               ' Digital I/O.
    Oct 2007
    I added:
    ... and everything is working properly. THANKS !
    Fabien
  1. My code for TV remote and MIBAM for RGB control
    By idtat in forum Code Examples
    Last Post: - 12th January 2013, 20:52
  2. Variable in array
    By Gusse in forum mel PIC BASIC Pro
    Last Post: - 22nd February 2009, 19:46
  3. Serout2/serin2 Pbp Problem
    By SOMRU in forum mel PIC BASIC Pro
    Last Post: - 11th December 2006, 19:55
  4. DS1820 headache
    By Calco in forum mel PIC BASIC Pro
    Last Post: - 12th August 2004, 00:28
  5. New member
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 28th February 2004, 22:44
