LCD display icon
Results 1 to 15 of 15
    Oct 2007
    Default LCD display icon
    hi i new to lcd and now playing with lcd to make an alarm clock.how can i made a bell icon display in lcd when i on the alarm?i attach the pic i get from internet.how can i made my LCD display like this?
    ... how can i made a bell icon display in lcd ...
    With this ...
    http://www.picbasic.co.uk/forum/showthread.php?t=2598
    Oct 2007
    Default lcd display blinking word non stop
    thanks for the help....:-)
    by the way, i got something don't understand
    why my display on second keep fresh and fresh in LCD and it made it look like blinking?
    is the any problem with my LCD display or need to add extra component?
    i using standard connection according to picbasic manual book.
    my LCD model:BONA MC1602-17
    I would guess a PAUSE of 100 some place after the LCD updates will stop the blink.
    Oct 2007
    here is my programe
    '4Mhz Crystal is use
    DEFINE LCD_LINES 2
    hour VAR BYTE
    dhour VAR BYTE
    minute VAR BYTE
    second VAR BYTE
    scaler VAR BYTE
    i VAR BYTE
    Pause 100 'wait lcd startup
    hour = 0
    minute = 0
    second = 0
    scaler = 0
    OPTION_REG = %11010101
    INTCON = %10100000
    display:
    LCDOut $fe,1
    dhour = hour
    IF (hour//12) = 0 Then
    dhour = dhour + 12
    EndIF
    IF hour < 12 Then
    LCDOut DEC2 dhour,":",DEC2 minute,":",DEC2 second, "AM"
    LCDOut $fe,$c0,"Simple Test"
    Else
    LCDOut DEC2 (dhour - 12),":",DEC2 minute,":",DEC2 second, "PM"
    EndIF
    GoSub timing
    GoTo display
    timing:
    scaler = scaler + 1
    IF scaler > 61Then
    scaler = 0
    second = second + 1
    IF second > 59Then
    second = 0
    minute = minute +1
    IF minute > 59Then
    minute = 0
    hour = hour + 1
    IF hour > 24 Then
    hour = 0
    EndIF
    EndIF
    EndIF
    EndIF
    where should i put the pause 100 and how i can display simple test in second line?
    it seem it run only time but didn't display simple test in second line
    Jun 2006
    Quote Originally Posted by cyber88 View Post
    here is my programe
    DEFINE LCD_LINES 2
    hour VAR BYTE
    dhour VAR BYTE
    minute VAR BYTE
    second VAR BYTE
    scaler VAR BYTE
    i VAR BYTE
    hour = 0
    minute = 0
    second = 0
    scaler = 0
    INTCON = %10100000
    display:
    LCDOut $fe,1
    dhour = hour
    dhour = dhour + 12
    EndIF
    IF hour < 12 Then
    Else
    EndIF
    pause 100 ' pause for .1 sec
    GoSub timing
    GoTo display
    timing:
    scaler = scaler + 1
    IF scaler > 61Then
    scaler = 0
    second = second + 1
    IF second > 59Then
    second = 0
    minute = minute +1
    IF minute > 59Then
    minute = 0
    hour = hour + 1
    IF hour > 24 Then
    hour = 0
    EndIF
    EndIF
    EndIF
    EndIF
    Add pause 100 before GoSub timing
    Oct 2007
    display:
    LCDOut $fe,1
    dhour = hour
    dhour = dhour + 12
    EndIF
    IF hour < 12 Then
    Else
    EndIF
    GoSub timing
    GoTo display
    thanks for the help. but i still cannot get display Simple test in LCD second line.
    is it my coding problem or my connection to LCD(i use last 4 bit to connect).
    if i use
    LCDOUT "hello"
    LCDOUT $fe,$c0,"simple test"
    it come out as i want.but with the above coding, it didn't show out.
    Jun 2006
    display:
    dhour = hour
    dhour = dhour + 12
    EndIF
    LCDOut $fe,1
    IF hour < 12 Then
    Else
    EndIF
    GoSub timing
    GoTo display
    Oct 2007
    thanks for the help
    here are my code for day
    symbol mon = 0
    symbol tue = 1
    symbol wed = 2
    symbol thu = 3
    symbol fri = 4
    symbol sat = 5
    symbol sun = 6
    hour var byte
    day var byte
    day = 0 ' initial day at mon when program run
    if hour > 24 then
    day = day + 1
    if day > 7 then
    day = 0
    lcdout $fe,$c0, dec3 day
    *the display only show 000, not mon.
    how i write the code to display date:month:year
    Jun 2006
    loop:
        hour = hour + 1
        if hour > 24 then
        day = day + 1
        if day > 7 then
        day = 0
       pause 200
    goto loop
    lcdout $fe,$c0, dec3 date ,":", dec3 month ,":", dec3 year
    Oct 2007
    code :
    loop:
    hour = hour + 1
    if hour > 24 then
    day = day + 1
    if day > 7 then
    day = 0
    pause 200
    goto loop
    i already try but the LCD display 000
    is it because my declare wrong here
    code:
    symbol mon = 0
    symbol tue = 1
    day var byte
    Jun 2006
    try this
    loop:
    hour = hour + 1
    if hour > 24 then
    day = day + 1
    if day > 7 then
    day = 0
    goto loop
    Oct 2007
    thanks....it work well now...now i want to made an alarm for my clock, i connect my buzzer at PORTB.0 for pic16f84.how should i write the alarm coding and it auto send signal to buzzer when the alarm is match?
    Oct 2007
    does anyone have a code for an alarm clock?my code for alarm seem not running.it cannot save the time i set to alarm the buzzer and whole alarm code not running.how can i save the time i set to alarm the buzzer and it auto wake me up everyday on that time without everyday set the alarm again?now i only left the alarm part for my LCD clock.can anyone please help me?
    i read the asm code, it say move the part i want to save into eeprom.how can i do that in picbasic?
  1. LCD Display
    By lambert in forum mel PIC BASIC Pro
    Last Post: - 16th January 2010, 23:18
  2. LCD display not working properly
    By dilpkan in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2008, 08:43
  3. Replies: 14
    Last Post: - 26th September 2007, 06:41
  4. LCD Display not working - PIC heating...
    Last Post: - 24th September 2006, 08:35
  5. A/D display result on LCD
    By winsthon in forum mel PIC BASIC Pro
    Last Post: - 10th January 2004, 11:09
