PIC18F4620 Using the Internal Oscillator
Results 1 to 4 of 4
Threaded View
  1. #3
    Quote Originally Posted by kiwipiper View Post
    Also Melanie showed me how to output a Decimal String by putting a # in front of the variable tone i.e. Serout 0, 6, [$1b, $52, 1, #tone]
    Can you output a hex or binary value instead and how do you do this?
    I am using MiroCode Studio and meProg
    Cheers Bruce
    Hi Bruce,
    I am not sure if this works with serout, but it does with SEROUT2, HSEROUT:
    BIN, HEX, DEC.
    from PBP manual Sec. 5.74 :
    "1) A string constant is output as a literal string of characters.
    2) A numeric value (either a variable or a constant) will send the corresponding ASCII character. Most notably, 13 is carriage return and 10 is line feed.
    3) A numeric value preceded by BIN will send the ASCII representation of its binary value. For example, if B0 = 8, then BIN B0 (or BIN 8) will send "1000".
    4) A numeric value preceded by DEC will send the ASCII representation of its decimal value. For example, if B0 = 123, then DEC B0 (or DEC 123) will send "123".
    5) A numeric value preceded by HEX will send the ASCII representation of its hexadecimal value. For example, if B0 = 254, then HEX B0 (or HEX 254) will send "FE".
    6) REP followed by a character and count will repeat the character, count time. For example, REP A0"\4 will send "0000".
    7) STR followed by a byte array variable and optional count will send a string of characters. The string length is determined by the count or when a 0 character is encountered in the string.
    BIN, DEC, and HEX may be preceded or followed by several optional parameters. If any of them are preceded by an I (for indicated), the output will be preceded by either a "%" , "#" , or "$" to indicate the following value is binary, decimal, or hexadecimal."
    http://www.melabs.com/resources/pbpmanual/
    JS
  1. Pic16f882 internal oscillator
    By offlander in forum mel PIC BASIC Pro
    Last Post: - 4th October 2009, 20:15
  2. Internal oscillator please help
    By timbash in forum mel PIC BASIC Pro
    Last Post: - 26th February 2009, 14:11
  3. Internal Oscillator
    By jhorsburgh in forum General
    Last Post: - 10th December 2007, 02:13
  4. PIC12F675, accuracy of baud rate with Internal Oscillator
    By Chris Mayhew in forum mel PIC BASIC Pro
    Last Post: - 31st August 2005, 22:41
  5. PIC12F629 w/ Internal Oscillator
    By RossW in forum mel PIC BASIC Pro
    Last Post: - 24th June 2004, 19:12
