hserin work 100% but if i use usbin code not work
Code:INCLUDE "modedefs.bas" asm __CONFIG _CONFIG1L, _PLLDIV_1_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L ; ; ; USB clock source comes from the 96 MHz PLL divided by 2 ; ; [OSC1/OSC2 Src: /1][96 MHz PLL Src: /2] ; No prescale (4 MHz oscillator input drives PLL directly) __CONFIG _CONFIG1H, _FOSC_XTPLL_XT_1H & _FCMEN_OFF_1H & _IESO_OFF_1H ; ; ; Oscillator Switchover mode disabled ; ; Fail-Safe Clock Monitor disabled ; XT oscillator, PLL enabled, XT used by USB __CONFIG _CONFIG2L, _PWRT_ON_2L & _BOR_ON_2L & _BORV_2_2L & _VREGEN_ON_2L __CONFIG _CONFIG2H, _WDT_OFF_2H __CONFIG _CONFIG3H, _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H & _CCP2MX_ON_3H __CONFIG _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _XINST_OFF_4L & _DEBUG_OFF_4L __CONFIG _CONFIG5L, _CP0_ON_5L & _CP1_ON_5L & _CP2_ON_5L & _CP3_ON_5L __CONFIG _CONFIG5H, _CPB_ON_5H endasm DEFINE OSC 48 DEFINE HSER_RCSTA 90h DEFINE HSER_TXSTA 20h DEFINE HSER_BAUD 9600 DEFINE HSER_CLROERR 1 Led Var PORTA.0 Recebe VAR PIR1.5 ' Receive interrupt flag (1=full , 0=empty) Transmite VAR PIR1.4 ' Transmit interrupt flag (1=empty, 0=full) Buffer VAR BYTE[16] Cnt VAR BYTE A VAR BYTE B VAR BYTE C VAR BYTE ADCON1 = 15 ' Set all I/Os to Digital INTCON2.7 = 0 ' Disable PortB Pullups CMCON = 7 ' Disable Comparators ' Interrupt Settings RCON.7 = 0 ' Disable Priority Interrupts, 1 to Enable ' Enable/Disable Interrupts INTCON.4 = 0 ' Disable INT0 (PORTB.0) INTCON3.3 = 0 ' Disable INT1 (PORTB.1) INTCON3.4 = 0 ' Disable INT2 (PORTB.2) INTCON.5 = 0 ' Disable TMR0 (Timmer 0) INTCON.6 = 1 ' Enable Peripheral Interrupts INTCON.7 = 1 ' Enable Global Interrupt Handler PIE1.4 = 0 ' USART Transmit Interrupt PIE1.5 = 1 ' USART Receive Interrupt PIE2.5 = 0 ' USB Interrupt PORTA = 0 TRISA = %00000000 HIGH LED PAUSE 1000 USBInit PAUSE 1 LOW LED ON INTERRUPT GOTO Interruptor ENABLE INTERRUPT '------------------------------------------------------------------------------- Inicio: USBService Cnt = 3 USBIn 3, Buffer, Cnt, Inicio GOTO usbSaida GOTO Inicio '------------------------------------------------------------------------------- DISABLE INTERRUPT Interruptor: IF Transmite = 1 THEN Transmite = 0 ENDIF IF Recebe = 1 THEN HSERIN 2, Continua, [Wait("<"), a, b] Buffer[0] = A Buffer[1] = B Buffer[2] = 13 Buffer[3] = 10 Cnt = 3 Recebe = 0 goto usbSaida ENDIF Continua: Recebe = 0 GOTO Fim '------------------------------------------------------------------------------- usbSaida: USBService USBOut 3, Buffer, Cnt, usbSaida goto Inicio '------------------------------------------------------------------------------- Fim: RESUME ENABLE INTERRUPT '------------------------------------------------------------------------------- END
