MOSFET driver
Results 1 to 5 of 5
Thread: MOSFET driver
    Aug 2007
    I have uploaded my circuit. When i use a diode instead of Q2 it works but i see little voltage about 13V with %98 duty cycle. How can I add Q2 to the circuit and drive them synchroniously. I use IR2111 and all of them are dead.
    Input voltage is 17V.
    Pwm Freq: 100Khz.
    you need to make your mind up on which vesrion you are using PBP or PDS ?
    Sep 2005
    Campbell, CA
    I see several problems here. First you are using N-Channel FETs for both devices. An N-Channel will only turn on when the gate is positive with respect to the source. You need to use a P-Channel device for Q1. You then hook the Source to your positive supply and pull the gate negative to turn it on. But you have another problem there - the gate-to-source voltage of most FETs is limited to 20V, so if you have a 17V supply, you should not pull the gate all the way to GND if you want to be safe.
    I would use a transistor as a driver for Q1. A 2N7000 FET would be a good choice. Connect the drain of the 2N7000 through a 1 K resistor to the gate of Q1 and connect a 4.7K resistor from Q1's gate to your positive supply. Connect the source of the 2N7000 to GND and the gate of the 2N7000 to your PIC.
    The 1K between the 2N7000's drain and Q1's gate, along with the 4.7K resistor acts as a voltage divider that prevents more than a 14V swing on Q1's gate.
    Q2 can be driven directly from the PIC, but it needs to be driven out-of-phase compared to the gate of the 2N7000. You will also need a little "dead-band" between the two outputs.
    That is, you do not want to drive the gate of the 2N7000 positive at the same instant you drive the gate of Q2 negative. You will need a little delay so that there is no time that Q1 and Q2 are turned on at the same time.
    I would probably replace Q2 with a Schottky diode and eliminate that hassle. The circuit's efficiency will be slightly less, but it is much easier in the long run.
    Charles Linquist
  1. Help needed - MOSFET driven by PWM
    By bcd in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2008, 05:02
  2. Mosfet problems
    By Agent36 in forum General
    Last Post: - 2nd February 2008, 22:37
  3. Self Destroying Mosfet with PIC
    By Josuetas in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2007, 16:42
  4. Driving a mosfet directly?
    By passion1 in forum mel PIC BASIC Pro
    Last Post: - 12th July 2007, 07:45
  5. MOSFET control using PWM & 16C711?
    By droptail in forum mel PIC BASIC Pro
    Last Post: - 27th June 2005, 02:24
