Cannot compile for 40MHz 4 x pll
Results 1 to 9 of 9
    Hangover, Germany
    Exclamation
    Quote Originally Posted by passion1 View Post
    Trying to track the reason for the continuous reset I display the values for
    Power-on-reset (POR), Brown-out reset (BOR) , stack full reset (STKFUL) and stack underflow reset (STKUNF) bits, but all are showing to be zero after each reset, so that does not seem to be the problem?
    WDT ?
    Missing Loop ?
    You have to write down all the CONFIG-Lines for all Config-registers !
    You have to read the other lines inside the files too !
    May 2007
    BigWumpus
    Thank you for the advice!
    Everything is working now!!
  1. 4 pin 4 x 4 keypad interface using pic basic pro
    By dunlao_john in forum mel PIC BASIC Pro
    Last Post: - 15th January 2009, 06:21
  2. Microcontroller with 2 way paging application problem
  3. 4 by 4 kepads routine
    By vladimir059@hot in forum mel PIC BASIC Pro
    Last Post: - 3rd March 2007, 23:19
  4. Real Time Clock & Eeprom
    By smart_storm in forum General
    Last Post: - 17th February 2006, 20:03
  5. having problems with Hantronix 20x4 lcd
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 13:22
