Software on PIC will come in loop after disconnect USB connection
Results 1 to 16 of 16
    Hi Ronald,
    There's a very simple solution to this. Assign a single I/O-pin as the USB bus-attach input.
    Here's how;
    ground --100k resistor----PIC input pin ----4.7k resistor----+V from USB connector.
    When the USB cable is plugged in, the input will see +V from the USB port. When the USB
    cable is removed, it will see ground.
    Don't attempt to send/receive any data until you see +V on the USB bus-attach input pin.
    Very simple. Very effective.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Oct 2003
    Australia
    Bruce,
    Thats a great tip, (although I havent seen this problem come up before).
    I'm wondering if this would be concidered a fail safe "Design Rule" and should be implemented into all USB PIC based circuits?
    Cheers
    Squib
    Hi Squib,
    I can't take credit for the idea. It's an option on the Microchip USB development board, and
    in the USB C firmware.
    There's no reason to enable the USB module if it's not attached, so it's not a bad idea to
    add in.
    -Bruce
    tech at rentron.com
    Sep 2007
    Hi Bruce, thank you for your almost exelent and simple sollution. Almost exelent because it will cost me 1 I/O and I don't have one I/O left. I have made a mistake because after testing this code again it was working.
    USBwriteStatus:
    USBService
    USBOUT 3, USBBUFFER ,CNT_UIT, exitusbwritestatus
    exitusbwritestatus:
    However this sollution has a disadvantage because when the outgoing USBBuffer is full it will also goto "exitusbwritestatus" without sending the information via USB, so some status information from PIC to PC will be lost.
    You should be able to determine if it's plugged-in or not by monitoring the usb_device_state variable.
    usb_device_state   VAR BYTE EXT
    CONFIGURED_STATE   CON EXT
    IF (usb_device_state = CONFIGURED_STATE) THEN
        ; OK to send
        ; Detached or Enumerating, don't try to send.
    Sep 2007
    Hi Darrel, I've tried it however it is not working. I've used the following.
    high dataled
    low dataled
    During USB connection the dataled is on. However the status of the dataled will not change when the USB cable will be disconnected. When I connect the cable in, for short time the dataled will be turned off and within about 300msec it will be turned on. I think that the Led will be turned off during enumeration.
    Do I something wrong why it is not working?
    Hi Ronald,
    I've done something similar before, but I didn't have a USB breadboard handy at the time I replied.
    I've dug out the old mister_e usbdemo breadboard.
    Blown off the dust with a half a can of "Dust-Off" ...
    ... and am taking a look.
    Hoping I can figure it out.
  1. Simple USB Comms Problem
    Last Post: - 6th January 2010, 21:17
  2. Using input from Switch to control a loop
    Last Post: - 2nd February 2009, 06:02
  3. Reading a slave USB with a pic
    By pcaccia in forum mel PIC BASIC Pro
    Last Post: - 25th October 2008, 13:00
  4. Two USB devices with same software, easyHID
    By Josuetas in forum mel PIC BASIC Pro
    Last Post: - 31st October 2007, 07:19
  5. PIC 2 PIC wireless connection
    By MegaADY in forum General
    Last Post: - 24th June 2004, 02:46
