Timer2
Results 1 to 3 of 3
Thread: Timer2
    swordman's Avatar
    swordman Guest
    Default Timer2
    How can I use timer2 with pause command?(16f877)
    For example:
    pause 7000 ' with tmr2
    Timer2 is not very versatile as it's an 8-bit Timer (eg 16F628). With both the Postscaler and Prescaler enabled you can only get 16*256*2 oscillator ticks out of it (check your PICs Datasheet). The longest timing sequence (at 4MHz) is therefore 8.192mS. You need some additional external variable as a counter (and associated processing code) to time intervals as long as your 7 second example. Is there a reason you don't want to use Pause?
    swordman's Avatar
    swordman Guest
    I want to use tmr2 ,like this
    for i = 1 to 900
    pause 8 'tmr2
    next i
    Can I set tmr2 to work with pause command?
  1. 16F726 Capacitive sensing module
    Last Post: - 15th May 2014, 20:40
  2. Half-bridge PWM with a 16F684 ?
    Last Post: - 17th January 2010, 23:18
  3. Timer1 and Timer2 interrupts, Darrel Taylor
    By ronbowalker in forum mel PIC BASIC Pro
    Last Post: - 17th December 2009, 19:38
  4. PWM pic16f873a(can i use timer2?)
    By Jadavjd in forum General
    Last Post: - 3rd April 2007, 21:44
  5. using counter using basic
    By islambadr in forum mel PIC BASIC Pro
    Last Post: - 20th August 2006, 21:13
