Serin vs Serin2
Results 1 to 13 of 13
Thread: Serin vs Serin2
    Yes, the timeout will let the program move on if the wait character is not seem. With out the time out, the program could "wait" forever.
    Depending on what you are doing you could decrease the timeout and check often, or use interrupts.
    Or to maybe speed things up-- wait for "X" and write "address" value to a VAR(doing that already).
    Then have some if / thens / else deciding what to do. This way the serial transmissions are short.
    Kind of like you said but the long string is not needed.
    Sorry if I am confusing things
    Jun 2007
    Mansfield, UK
    that idea about putting the address into a variable and using if-then is how i had it in the first place. the trouble i had is that it would fire when the string gets sent out and try to read the first bunch of bytes. if the address didnt match it would return to serin but by that time the rest of the data has already passed.
    there is only 1 string that gets sent out of the PC but that string has the values for all the chips in it
  1. Serin to Serin2 ??
    By Gixxer in forum mel PIC BASIC Pro
    Last Post: - 25th January 2008, 04:56
  2. serin and serin2??? need to understand
    By tkly36 in forum mel PIC BASIC Pro
    Last Post: - 7th April 2006, 06:13
  3. Serin / Serin2 / Debugin Differences
    Last Post: - 19th January 2006, 07:32
  4. SERIN SERIN2 Timeout
    By markedwards in forum mel PIC BASIC Pro
    Last Post: - 23rd June 2005, 19:59
  5. serin and serin2
    By rastan in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2005, 14:10
