Serin vs Serin2
Results 1 to 13 of 13
Thread: Serin vs Serin2
    19200 according to the manual is the top end for SERIN/OUT2. You will need an OSC faster than 4MHz though.
    Look at appendix A
    Jun 2007
    Mansfield, UK
    oh. do you know the fastest for a chip using 4MHz?
    At 4MHz the recommended is less than 9600. 9600 will work at 4MHz if all is stable.
    There is some debate, but I do not like the internal OSC for serial, I use a crystal resonator (the ones with three pins, built in caps) seem to be very stable.
    Jun 2007
    Mansfield, UK
    ahh, i cant go any higher then. i use an external oscillator anyway because thats the way i was shown how to do it. everything seems to be working fine now. i had a bug that looked like the serin command wasnt running fast enough but i turned out to be the wait() part.
    the way ive solved it has created another question. the chips must wait for 250 and their own unique ID before doing something. that bit works fine but i want to be able to send a command that resets their ID no matter what it is.
    the code im using now is
    serin2 porta.2,16468,2000,nocmd,[wait(250,address),cmd,val]
    can i tell it to do something if it gets 251 and anything *aswell*? if not then i have a backup plan but i would rather do it that way
    Quote Originally Posted by The Master View Post
    ahh,
    If I understand what you want the answer is yes. After the TIMEOUT for the 250 ends you could have it WAIT for 251.
    serin2 porta.2,16468,2000,nocmd,[wait(251,?????),cmd,val]
    serin2 porta.2,16468,2000,nocmd,[wait(252,?X?X?X),cmd,val]
    Something like that
    But this will eat up speed. Maybe decrease the TIMEOUT?
    Jun 2007
    Mansfield, UK
    hmm, i see what thats doing. the timeout is designed to turn the outputs off if there is no data for 2 secs. the serin really does need to wait for 250,address all the time. just waiting for 250 then using an if-then statement to check the address takes enough time to cause problems.
    i suppose the only way to do it is to send a long string from the PC that includes 250 and every address that i might use (about 1 to 40 should do)
    Yes, the timeout will let the program move on if the wait character is not seem. With out the time out, the program could "wait" forever.
    Depending on what you are doing you could decrease the timeout and check often, or use interrupts.
    Or to maybe speed things up-- wait for "X" and write "address" value to a VAR(doing that already).
    Then have some if / thens / else deciding what to do. This way the serial transmissions are short.
    Kind of like you said but the long string is not needed.
    Sorry if I am confusing things
  1. Serin to Serin2 ??
    By Gixxer in forum mel PIC BASIC Pro
    Last Post: - 25th January 2008, 04:56
  2. serin and serin2??? need to understand
    By tkly36 in forum mel PIC BASIC Pro
    Last Post: - 7th April 2006, 06:13
  3. Serin / Serin2 / Debugin Differences
    Last Post: - 19th January 2006, 07:32
  4. SERIN SERIN2 Timeout
    By markedwards in forum mel PIC BASIC Pro
    Last Post: - 23rd June 2005, 19:59
  5. serin and serin2
    By rastan in forum mel PIC BASIC Pro
    Last Post: - 3rd January 2005, 14:10
