PIC18F4620 not Target Device
Results 1 to 3 of 3
    Oct 2007
    Default PIC18F4620 not Target Device
    Greetings,
    I just got a PIC18F4620 in the mail and tried to program it.
    I have the MeLabs U2 USB PIC Programmer attached to the MeLabs 840Z 40-Pin ZIF Adapter
    I use MicroCode Studio to write the code in PBasic then I use compile and program. This then does a bunch of stuff and opens meProg. I then click Program and it does its stuff and programs the PIC (wonderful). It has been working great with the PIC16Fxxx's I have been using so far.
    When I put the PIC18F4620 (Correct way as per diagram) I get an error message from the meProg. The error message is:
    "Error: Target device does not match selected device."
    Some Things It is Not:
    I have PIC18F4620 in the selection box in both MicroCode Studio and meProg
    Seems to complile fine in MicroCode Studio
    I can read from the PIC in meProg
    Other Information:
    If I click Get Target Information in meProg I get the following.
    - melabs U2 Programmer
    - Firmware version is 4.8.
    - Target device ID is FFFF
    - Target device does not match selected device.
    Anyone have any ideas
    Cheers Bruce
    Is the ribbon cable from programmer to 840Z ZIF plugged into the header on the ZIF
    socket where it's marked 28-40 pin Connection?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Oct 2007
    Lightbulb What would I do without you guys
    Of Course..... how could I miss that. To much staring at computer screens, I am going blind. Thanks again for the quick and perfect answer. I do appreciate the advice and hopefully will one day build up enough knowledge to be able add some value to this excellent forum.
    Cheers Bruce
  1. Watchdog Timers
    Last Post: - 27th August 2014, 19:03
  2. ICDWarn0020: Invalid target device id
    By pravec065 in forum General
    Last Post: - 4th August 2008, 14:43
  3. Replies: 8
    Last Post: - 24th April 2008, 23:19
  4. Target device does not match
    By krohtech in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2008, 05:20
  5. Target device <> Selected Device????
    By deepgfishing in forum mel PIC BASIC Pro
    Last Post: - 20th June 2007, 22:18
