4Mhz Circuit with a 20Mhz PIC
Results 1 to 16 of 16
    Perth, Australia
    I assume you have the following line at the top of your PBP program:
    Thats the only setting I can think of that you would need to worry about.
    What does happen? Does everything happen at the wrong speed, or does the PIC refuse to do anything at all?
    Here is my code, and nothing at all happen
    With the PIC16F877-20l/P it is working, but when I switch it with the PIC16F877-20/P it does not work.
    <code>
    &nbsp;&nbsp;Include "Modedefs.bas"
    &nbsp;&nbsp;DEFINE OSC 4 ' Set the Xtal frequency to 4mHz
    &nbsp;&nbsp;LEDPin VaR PORTC.2
    &nbsp;&nbsp;i var byte
    &nbsp;&nbsp;for i = 1 to 10
    &nbsp;&nbsp;&nbsp;&nbsp;High LEDPin
    &nbsp;&nbsp;&nbsp;&nbsp;Pause 400
    &nbsp;&nbsp;&nbsp;&nbsp;Low LEDPin
    &nbsp;&nbsp;next i
    </code>
    Mar 2006
    China
    Default Config bits?
    At 20 MHz I guess you use "HS" for 20 MHz but for 4 MHz "XT" would be a better choice.
    What do you clock it with? do you have a 4MHz x-tal or osc?
    /me
    Jumper
    Thank you very much for your feedback.
    I do have my Oscillator setting on "XT" and I'm using a 4Mhz X-tal.
    Koossa
    Feb 2003
    Salt Lake City, Utah USA
    ... a long shot but try blinking RB0 instead of RC2 (and report back).
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    I have moved my LED to RB0 and change my code, but not one of them are working now.
    Am I missing something?
    <code>
    &nbsp;&nbsp;LEDPin VaR PORTB.0
    &nbsp;next i
    </code>
    Have you tried Oscillator setting on "HS"?
  1. PIC backup power supply: switchover ???
    Last Post: - 18th April 2008, 17:05
  2. Circuit Diagram for interfacing AC to PIC IC?
    By wellyboot in forum Schematics
    Last Post: - 8th March 2008, 19:40
  3. Pic driven digital audio delay
    By skimask in forum Off Topic
    Last Post: - 19th April 2007, 20:42
  4. Circuit needed to allow a PIC to turn something on or off
    Last Post: - 12th October 2005, 21:17
