Controlling AC motors
Results 1 to 24 of 24
    Jun 2007
    Mansfield, UK
    Ive had a more detailed read of it. It looks clever but im not sure how i would use it. Would i buy converters or would i have to program the chips and use standard I/O?
    Yes, you would need a 232 to 485 converter, the programing would be the same.
    Big advantage is distance and "multiple devices".
    If you interested search the forum, several discussions about converters, suppliers, and such. I have not used 485 enough to know all of the ins and outs, just enough to know it works well.
    Jun 2007
    Mansfield, UK
    Sounds good. Im not doing long distance stuff yet but i will be in the future i hope. Maby only 1 or 2 hundred meeters though. In any case i will probly be using at least 10 chips on each dataline
    Forgot to mention that the first time I used it was in a situation with a lot of electrical noise. Sending date to a CNC plasma machine RS232 was not reliable and RS485 solved the problem.
    Good luck.
  1. DC to AC convertor
    Last Post: - 6th February 2010, 18:44
  2. Controlling stepper motor with PIC
    Last Post: - 1st July 2008, 11:21
  3. Circuit Diagram for interfacing AC to PIC IC?
    By wellyboot in forum Schematics
    Last Post: - 8th March 2008, 20:40
  4. How to read AC mains with an inductance coil
    By KB3BYT in forum mel PIC BASIC Pro
    Last Post: - 20th February 2008, 13:02
  5. Special Offer AC -AC adapter
    By lester in forum Adverts
    Last Post: - 9th September 2005, 08:52
