PWM - Mosfet/motor introducing noise
Results 1 to 12 of 12
    QUOTE=DynamoBen
    The mosfet can't be moved. I don't know if I have a low ESR cap. I can dig through my parts bin. Anything specific I should be looking for?
    > IF I tell you BC Components (ex. Philips ) Series 136 ... ESR <= 22 mOhms ( Milli ...yes ! )
    Is this in addition to the above cap?
    > The .1µF capacitor must be soldered ON the motor terminals ...
    Will try.
    > The 10nF are also necessary.
    I don't have anything like this lying around.
    > Not compulsory, yes ...but highly recommended !!!
    Jun 2005
    Wisconsin
    This seems to be what you are describing.
    http://www.kronosrobotics.com/an142/GAN142.htm
    Wink
    Quote Originally Posted by DynamoBen View Post
    Hi, Ben
    Yes ... that's a nice tutorial ... but some tips still missing !!! ( diode, low esr cap, inductor ...)
    note here, in this example, motors can be reversed ... so, the diode can't be placed on the motor terminals, but close to the "reversing commutator" ( relay, transistors bridge ...)
  1. Half-bridge PWM with a 16F684 ?
    Last Post: - 17th January 2010, 23:18
  2. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 07:03
  3. PWM: Vernacular/Function (Newbee)
    By TerryN in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2008, 17:58
  4. PWM setting PIC16F887
    By Gevo in forum mel PIC BASIC Pro
    Last Post: - 12th June 2008, 08:24
  5. Tidying Up PWM Routine
    Last Post: - 21st February 2005, 01:26
