PWM - Mosfet/motor introducing noise
Results 1 to 12 of 12
    Jun 2005
    Wisconsin
    Your diode parallelled to the mosfet must be paralleled to the MOTOR ... that will GREATLY limit the spikes ( 1N400x seems a bit Weak for this kind of motor ... try better 1N540x or a fast recovery TO220 model )
    The schematic isn't correct in this case, the diode seems to be drawn wrong. However I will try moving the diode up to the motor. I will try to located a different diode...
    1) place a low ESR 1000µF or + capacitor as close as possible to the motor ... to lower the 12v power source impedance. ( by the way, I'm saying the mosfet could be placed close to the motor ...and the diode between motor terminals ...)
    The mosfet can't be moved. I don't know if I have a low ESR cap. I can dig through my parts bin. Anything specific I should be looking for?
    2) place a .1µF on your motor terminals
    Is this in addition to the above cap?
    3) place a 10nF between each motor terminal and motor frame which has to be connected to circuit ground.
    Will try.
    4) you can place a core coil ( 1mH range "big value" ) in series beetween 12 v and your 5v reg input
    I don't have anything like this lying around.
    QUOTE=DynamoBen
    > IF I tell you BC Components (ex. Philips ) Series 136 ... ESR <= 22 mOhms ( Milli ...yes ! )
    > The .1µF capacitor must be soldered ON the motor terminals ...
    Will try.
    > The 10nF are also necessary.
    > Not compulsory, yes ...but highly recommended !!!
    Jun 2005
    Wisconsin
    This seems to be what you are describing.
    http://www.kronosrobotics.com/an142/GAN142.htm
    Wink
    Quote Originally Posted by DynamoBen View Post
    Hi, Ben
    Yes ... that's a nice tutorial ... but some tips still missing !!! ( diode, low esr cap, inductor ...)
    note here, in this example, motors can be reversed ... so, the diode can't be placed on the motor terminals, but close to the "reversing commutator" ( relay, transistors bridge ...)
  1. Half-bridge PWM with a 16F684 ?
    Last Post: - 17th January 2010, 23:18
  2. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 07:03
  3. PWM: Vernacular/Function (Newbee)
    By TerryN in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2008, 17:58
  4. PWM setting PIC16F887
    By Gevo in forum mel PIC BASIC Pro
    Last Post: - 12th June 2008, 08:24
  5. Tidying Up PWM Routine
    Last Post: - 21st February 2005, 01:26
