Strange problem with PBP 2.50
Results 1 to 3 of 3
    Sep 2005
    Campbell, CA
    Default Strange problem with PBP 2.50
    The following code compiles and runs fine under PBP 2.47
    but hangs forever in PBP 2.50
    B0 = $AA
    Addr = 65534
    I2CWRITE SDA1,SCL1,RevABase,addr,[B0]
    Pauseus 20
    I2CWRITE SDA1,SCL1,RevBBase,addr,[B0]
    PAUSEus 20
    I2CWRITE SDA1,SCL1,RevCBase,addr,[B0]
    PAUSEus 20
    I2CREAD SDA1,SCL1,RevABase,addr,[B1]
    PAUSEus 20
    I2CREAD SDA1,SCL1,RevBBase,addr,[B2]
    PAUSEus 20
    I2CREAD SDA1,SCL1,RevCBase,addr,[B3]
    The I2C device is an EEPROM.
    "RevxBase" is a BYTE variable
    "Addr" is a word variable
    Clock is 40Mhz, but I have the define "I2C_SLOW 1"
    2.2K pull-ups are used on SDA and SCL
    PIC is 18F8722
    The program hangs whenever I do a I2CWRITE -or- I2CREAD
    Has anyone else had this problem with 2.50?
    Charles Linquist
    Charles Linquis, I have recompiled a program w/PBP2.50 that uses 2 24LC1025's and have had no problem... This is the code I use:
    READ_WRITE_BLK1025: 'WRITE TO or READ FROM SERIAL EEPROM NEXT AVAILABLE STORAGE BLOCK
    SCL = 0 'PRESET CLOCK STATE TO LOW
    ADDRESS = 65534 'POINT TO LAST STORED DATA(WORD) ADDRESS
    CNTROL_BYTE = CNTRL_BYTE 'COPY CONTROL BYTE
    CNTROL_BYTE.1 = 1'DEVICE.1 'SET LSB OF HARDWARE ADDRESS
    CNTROL_BYTE.2 = 0'DEVICE.2 'SET MSB OF HARDWARE ADDRESS
    CNTROL_BYTE.3 = 1'DEVICE.0 'SET 64K BLOCK BIT
    IF READ_WRITE = 1 THEN
    INTCON.7 = 0 'DISABLE ALL INTERRUPTS
    I2CWRITE SDA,SCL,CNTROL_BYTE,ADDRESS,[BLOCK.LOWBYTE,BLOCK.HIGHBYTE] 'WRITE DATA POINTER TO 12C
    INTCON.7 = 1 'RE-ENABLE ALL INTERRUPTS
    PAUSE 6 'ALLOW TIME FOR I2C WRITE ~5Ms.
    I2CREAD SDA,SCL,CNTROL_BYTE,ADDRESS,[BLOCK.LOWBYTE,BLOCK.HIGHBYTE] 'READ DATA POINTER FROM 12C
    Sep 2005
    Campbell, CA
    This says it all -
    Hi Charles,
    There seems to be a problem with the I2C_SLOW define. We are
    investigating.
    Charles Leo
    microEngineering Labs, Inc.
    Charles Linquist
  1. PBP 2.60 & ADCON1 problem
    By bitbangerbob in forum mel PIC BASIC Pro
    Last Post: - 21st October 2009, 13:06
  2. PIC stop responding - Strange Problem!
    Last Post: - 31st August 2009, 15:06
  3. PBP 2.50 UPGRADE problems!!!!
    Last Post: - 7th March 2008, 16:42
  4. MCS+ with PBP 2.50
    Last Post: - 21st September 2007, 06:52
  5. Instant interrupt problem (very strange)
    By yusoweird in forum General
    Last Post: - 31st October 2006, 17:15
