120v control
Results 1 to 12 of 12
Thread: 120v control
    The only problem with SSR is you need an appropriately sized heatsink whereas a standard relay does not. However you can't drive a power relay directly from a PIC. Either way has it's advantages and disadvantages. Also you can get SSR zero-cross switching built into them. This is really nice for switching inductive loads like motors.
    Dont want to steal the thead, but,
    i have one 5v relay ( EDR201A0500 ) and it can switch up to 250VDC.
    My question is, with this relay can i connect the pic directly to the relay ( no transistor required ) ?
    Edit:
    http://www.ece.com.tw/product/relay/edr/edr.htm
    It does say "The high sensitivity allows direct driving by TTL", so it means i do not need the transistor. And this is a cheap relay (2.5 euros )
    I personally switch all relays with a transistor. Even the little zero-cross SSR we use require 20mA to work properly.
    Hi ruijc,
    I=E/R so I=5volts /500 ohm coil so I=.01amp or 10 ma. Unless my calculator lied it should work, make sure to install a diode to protect the port from back EMF.
    Sep 2007
    For driving relays I use an NPN darlington array DIP. Drive 8 relays for $.72 and has the diode built in to protect the pic from inductive spikes. If you are going to do home automation you will probable need many channels and these work very well.
    see: ULN2803APG
    http://search.digikey.com/scripts/Dk...=ULN2803APG-ND
    OOPS I see Jerry already recommended a darlington driver, let me change my answer to "I agree with Jerry on the driver chip"
    Best Regards,
    Kurt A. Kroh
    KrohTech
    “Goodbye and thanks for all the fish”
  1. How do I give a radio control car autonomous control
    By Kenjones1935 in forum General
    Last Post: - 17th January 2010, 15:40
  2. pt2258+16f877 how can i use for 5.1 volume control ?
    By whyliving in forum mel PIC BASIC Pro
    Last Post: - 26th January 2008, 17:51
  3. No one-way approach to learning ir remote control frequencies
    By selbstdual in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2007, 13:26
  4. Control unlimited servos at the same time
    By mrx23 in forum mel PIC BASIC Pro
    Last Post: - 19th September 2006, 14:14
  5. Control RC servo via Parallax Servo Control
    Last Post: - 17th September 2005, 08:18
