4Mhz Circuit with a 20Mhz PIC
Results 1 to 16 of 16
    Default 4Mhz Circuit with a 20Mhz PIC
    Good day Picers!
    I have layout an easy LED blink circtuit at 4Mhz.
    I only have 20Mhz PICs, 1 x PIC16F877-20l/P and 2 x PIC16F877-20/P
    When I program the PIC16F877-20l/P @ 4Mhz it works fine, but when I program the PIC16F877-20/P it does not work and it's exactly the same circuit.
    Is there any setting to get this Pics working @ 4Mhz?
    Thank you!
    Koossa
    Perth, Australia
    I assume you have the following line at the top of your PBP program:
    Thats the only setting I can think of that you would need to worry about.
    What does happen? Does everything happen at the wrong speed, or does the PIC refuse to do anything at all?
    Here is my code, and nothing at all happen
    With the PIC16F877-20l/P it is working, but when I switch it with the PIC16F877-20/P it does not work.
    <code>
    &nbsp;&nbsp;Include "Modedefs.bas"
    &nbsp;&nbsp;DEFINE OSC 4 ' Set the Xtal frequency to 4mHz
    &nbsp;&nbsp;LEDPin VaR PORTC.2
    &nbsp;&nbsp;i var byte
    &nbsp;&nbsp;for i = 1 to 10
    &nbsp;&nbsp;&nbsp;&nbsp;High LEDPin
    &nbsp;&nbsp;&nbsp;&nbsp;Pause 400
    &nbsp;&nbsp;&nbsp;&nbsp;Low LEDPin
    &nbsp;&nbsp;next i
    </code>
    Mar 2006
    China
    Default Config bits?
    At 20 MHz I guess you use "HS" for 20 MHz but for 4 MHz "XT" would be a better choice.
    What do you clock it with? do you have a 4MHz x-tal or osc?
    /me
    Jumper
    Thank you very much for your feedback.
    I do have my Oscillator setting on "XT" and I'm using a 4Mhz X-tal.
    Koossa
    Feb 2003
    Salt Lake City, Utah USA
    ... a long shot but try blinking RB0 instead of RC2 (and report back).
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    I have moved my LED to RB0 and change my code, but not one of them are working now.
    Am I missing something?
    <code>
    &nbsp;&nbsp;LEDPin VaR PORTB.0
    &nbsp;next i
    </code>
    Have you tried Oscillator setting on "HS"?
    No
    I will try
    I have set it to HS, but still nothing.
    Attach the compiled .HEX file that you are programming into the PIC here. If there's a
    problem with your config settings, that makes it easy for someone to spot.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Bruce
    Attached the zipped hex file.
    Thank you very much for your time!
    Hi Koossa,
    The good news is - config settings look fine. XT osc, WDT on, PWRT on, brownout on,
    LVP off, protection off. Looking good here if you're using a 4MHz external crystal.
    The bad news is - this code isn't anywhere near what you show above just trying to
    toggle an LED.
    It sets up the USART for 19,200bps at 4MHz, shoots out a single letter f, then sits & spins
    waiting for serial data input, in a loop watching the RCIF flag bit.
    Are you 100% sure you're actually programming the file you expect into your 877?
    The .HEX file you have attached is for sure not the one you show above trying to toggle
    an LED....;o}
    -Bruce
    tech at rentron.com
    Hello Koossa,
    try adding this to your code:
    CCP1CON = 0 ' DISABLE CAPTURE COMPARE MODULE
    TRISC = %00000000 ' SET ALL PORT C TO OUTPUTS
    JS
    Sep 2007
    I think this code was compiled using the MicroCode Studio Plus ICD Compile. It won't run in the PIC unless there is an ICD connection to the PC.
    If you intended to run the code without the ICD, find the "normal" compile/program buttons in MicroCode Studio Plus. Don't use ICD Compile or ICD Compile And Program unless you have the ICD connection hooked up.
    Charles Leo
    microEngineering Labs, Inc.
    http://melabs.com
    Thank you Charles_Leo, you are correct, it's been a while since I last use this software so I was a bit rusty.
    Joe S., I have added your code and everything is working now
    Thank you very much!!!
  1. PIC backup power supply: switchover ???
    Last Post: - 18th April 2008, 17:05
  2. Circuit Diagram for interfacing AC to PIC IC?
    By wellyboot in forum Schematics
    Last Post: - 8th March 2008, 19:40
  3. Pic driven digital audio delay
    By skimask in forum Off Topic
    Last Post: - 19th April 2007, 20:42
  4. Circuit needed to allow a PIC to turn something on or off
    Last Post: - 12th October 2005, 21:17
