A2D on PIC 16F685
Results 1 to 8 of 8
Threaded View
  1. #8
    What version of PBP are you using?
    I don't have a 685 to test this with, but I ran it through MPSIM using ADCIN, and it appears to work
    fine with v2.47. The only difference is instead of setting ADCON1.7 for right justification, you need to
    set ADCON0.7. Give this a shot and let me know if it works.
    @ DEVICE PIC16F685,MCLR_OFF,WDT_OFF,INTRC_OSC_NOCLKOUT,PROTECT_OFF
    DEFINE ADC_BITS 10
    ' Set clock source (3=rc)
    DEFINE ADC_CLOCK 3
    ' Set sampling time in microseconds
    DEFINE ADC_SAMPLEUS 10
    adcVar VAR WORD ' Create variable to store result
    Index  VAR BYTE ' Loop index for channels
    ' Set PORTA to all input
    TRISA = %00000111 ' AN0 to AN2 inputs
    ANSEL = %00000111 ' AN0 to AN2 analog inputs, rest digital
    ANSELH = 0        ' AN8 to AN11 digital
    ' Set up ADCON0 (not ADCON1) like in the manual
    ADCON0 = %10000000 ' right justify for 10-bit
    Pause 500        ' Wait .5 second
    HIGH PORTB.6     ' Turn on status LED
      FOR Index = 0 TO 2 ' Display 3 channel results
          ADCIN Index,adcVar ' Read AN0 to AN2
          GOSUB Display      ' Display channel results
      NEXT Index
      Pause 10  ' Wait.01 second
      GoTo main ' Do it forever
    Display:
      serout portb.7, 6, ["Channel #",#Index,#adcVar]
    You can enable more A/D pins if you need to by setting the ANSEL or ANSELH bits for each port pin
    with A/D like shown in the data sheet.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 11:00
  2. Replies: 67
    Last Post: - 8th December 2009, 03:27
  3. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 15:46
  4. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 22:01
