Setting Address via ADC
Results 1 to 3 of 3
    Jun 2006
    Default Setting Address via ADC
    Just wondering if anyone has any experience or thoughts on setting the ID of a PIC by using the ADC and a resistor network, and mapping the value to an ID on startup. I would like to be able to use an 8-pin chip in a project where I have about 30 devices on a common serial line, but will only have a single free pin. I am aware that the maximum impedance recommended by the datasheet is 10 kOhm and the ADC is 10-bit. I believe the 1% tolerance resistors come in frequent values, hence my thought was something along the lines of a 1k pull up resistor, and using values spaced from 0 to 9k between the pin and ground, thus producing a range of voltages between 0 and 4.5V (5V supply).. Naturally the ADC value will not be exact (nor will resistor voltages), but if I aimed for 50 devices, by my calculations that would leave me +/- 9 ADC values before reading the wrong ID. Is this too small? This is also assuming I can find a perfectly spaced range of resistor values. Space and cost are crucial, hence the choice of small and cheap resistors. Doable?
    Daniel
    Bombay, India
    Definitely doable, but not necessarily a workable idea. The fact that your IDs are located across 50 devices, brings into play Vcc considerations too. If the VCC across devices varies, you will have ID overlaps. So, it may not work.
    breesy, As long as you have the reference for the A/D selected as VDD and VSS as well as the same source used for the resistor divider then it wil work perfectly. The A/D is then ratiometric as far as the source voltage. I would use 1% resistors with the same temperature coefficient.
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 22:14
  2. PICKit2 - warning about configuration words
    Last Post: - 4th August 2009, 14:01
  3. Setting up ADC....
    By robertmark68 in forum General
    Last Post: - 11th August 2006, 18:08
  4. Setting Up Adc Ports
    By GEEZER in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2005, 03:04
  5. 18f452 internal eprom help
    By TONIGALEA in forum mel PIC BASIC Pro
    Last Post: - 13th July 2004, 15:50
