PBP does not disntigush between upper or lower case.
example...
MyVaR var BYTE
MYVAR=5
LCDOut $FE,1,#myvar
This is all quite valid... MyVaR, myvar and MYVAR is all regcognised as the same variable. The same applies to labels...
StartHere:
starthere:
STARTHERE:
StArThErE:
... again all are recognised as being the same label.
At this time you cannot change the way the PBP compiler parses your source code.
Naturally, PICBasic DOES distinguish between UPPER and lower case when we talk about data and variables. For example...
SERIN2 1,16780,[WAIT(“A”),B0]
is not the same as...
SERIN2 1,16780,[WAIT(“a”),B0]
