Pic Power
Results 1 to 7 of 7
Thread: Pic Power
    Sep 2007
    Question Pic Power
    Hi Guys & Dolls!
    i got an electronic problem and donīt know if it could be solved by a single PIC or if I have to use two.
    Heres the Problem concerning an automobile ignition circuit:
    I got pulses with a frequency ratio of about 20 to 1 : from ca. 150 ms (engine cranking) to 2 ms. The coil needs 1 ms for charging.
    first process: measuring pulse lenght (pulsin could do that)
    second: starting charging the coil after "pulse lenght - 1 ms" that leaves the one ms and the follows the ignition .
    this has to be done real fast! and the pulse lenght changes often.
    do I need two pics?or three? is PBP fast enough?
    tried this with a 12F629 without success because i need one loop for pulsin and a second one for the output.
    can anyone help? Hi mister_e! (did me a favor two weeks ago)
    Smile
    I do not wear skirts ...
    but have realized such an electronic ignition device aboard 12F629/16F84 ...
    Using assembler ... works really fine . and there's room left !!!
    Using PbP( with a touch of assembler ... ) ... did not give - to the day - really usable results for a 0° crank detector setting.
    research is in progress ...
    But one thing is sure ... you must have many timers running at the same time !!!
    Sep 2007
    Wink solution done?
    Hi Ace,
    you got that already running? I donīt need a 0° crank detector, a constant difference to 0 would do.
    how do I get that software/schematic? left hand washes right foot or so?
    Sep 2007
    Unhappy French? omygod....
    thanks for that.
    but: i donīt even know 0,001% of the french language.
    Argl-Garg!
    loaded some software fromthat site, didnīt even know what for and the Windows Instructions in french......could be Hindi or Serbocroatic or the famous african language with the lot of klicks....
    Angry
    I had a really nice Excel sheet to load the ignition timings, processor and options ... into theASM program ( using MPLAB ) ...
    But I recently discovered the Excel functions are in various languages ... so, the sheet developped with a French edition doesn't work in Foreign countries.
    Some more thanks to Bill Gates ...
    Sep 2007
    Unhappy only single cylinder
    yeah the english only like singles which doesnīt hdisturb,
    but the software is only in hex.......as one would expect. so i coulndīt modify it for my needs.
  1. Pic getting part power from Analog Port
    By ShaneMichael in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2009, 10:34
  2. Ideal backup power for PIC micro
    By emavil in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2007, 00:07
  3. PIC power backup with "super capacitor"
    Last Post: - 24th January 2007, 23:51
  4. problems on power up of PIC
    By dmairspotter in forum mel PIC BASIC Pro
    Last Post: - 13th June 2006, 14:11
  5. Controlling power to a PIC with another PIC
    By jswayze in forum Off Topic
    Last Post: - 28th May 2005, 19:44
