macro's
Results 1 to 3 of 3
Thread: macro's
    Default macro's
    hello,
    after reading the board for string handling, again the solution is DT fantastic examples..
    but trying to combine interuptmodule ( macro) and the getaddress module ( for string handling) the compiler generates errors.
    duplicate macro name ( getaddress)
    is it not possible to use more than one macro ?
    the Hserout is not needed - just copy - paste to try ...
    used pic is 18F4525
    '* Name : STRINGS-16.PBP *
    '* Author : Darrel Taylor *
    '* Date : 6/12/2005 *
    '* Note: Strings must be NULL Terminated *
    DEFINE LOADER_USED 1 ' If using bootloader
    DEFINE HSER_TXSTA 24h ' Use this for Higher Baud Rates
    DEFINE HSER_SPBRG 25 ' 9600 Baud at 4mhz
    Addr var word
    Char var byte
    Clear
    ' include special interupts
    INCLUDE "DT_INTS-18.bas" ; Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas" ; Include if using PBP interrupts
    INCLUDE "Elapsed_INT-18.bas" ; Elapsed Timer Routines
    goto StartLoop ' Required
    String1:
    @ da "This is a string",0
    AnotherString:
    @ da "Here is another string",0
    '------------GetAddress Macro - Location insensitive -------------------------
    GetAddress macro Label, Wout ; Returns the Address of a Label as a Word
    CHK?RP Wout
    movlw low Label
    movwf Wout
    movlw High Label
    movwf Wout + 1
    INT_Handler TMR1_INT, _ClockCount, PBP, yes
    StartLoop ' This loop repeats continuously just as a test.
    @ GetAddress _String1, _Addr ' Get address of String
    gosub StringOut ' Send the String
    hserout [13,10] ' New Line
    @ GetAddress _AnotherString, _Addr ' Get address of String
    goto StartLoop ' Repeat
    StringOut: ' Send the string out via Hserout
    Readcode Addr, Char ' Get a character
    if Char = 0 then StringDone ' Look for Null char, Stop if found
    hserout [Char] ' Send char
    Addr = Addr + 1 ' Point to next character
    goto StringOut ' Continue with rest of the string
    StringDone:
    rgds
    harry
    It's possible to use as many macros as you want, but you can't have two with the same
    name.
    GetAddress is already included in DT_INTS-18.bas. Just use this one.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    many thanks Bruce,
    i will try it out !.
    and it works --- fast reply !!! very helpfull
    rgds
    Harry
  1. Embedded Strings in your Code Space
    By mytekcontrols in forum mel PIC BASIC Pro
    Last Post: - 9th March 2008, 08:50
  2. Schematic Drawing Programs
    By fowardbias in forum Off Topic
    Last Post: - 3rd April 2007, 16:38
  3. Assembly Macros
    By Dick Ivers in forum mel PIC BASIC Pro
    Last Post: - 17th March 2006, 22:02
  4. Making PBP code more modular
    By forgie in forum General
    Last Post: - 25th October 2005, 17:24
  5. macros tutoria
    By asterix in forum mel PIC BASIC
    Last Post: - 4th May 2005, 10:09
