MPASM vs PM
Results 1 to 3 of 3
Thread: MPASM vs PM
    Oct 2003
    Australia
    Default MPASM vs PM
    What are the advantages of using either of these compiliers over the other?
    I know that 18Fxxxx need to be compiled with MPASM (microchip's assembler) but 16Fxxx etc can use either.
    PM appears to be a bit quicker then MPASM, and I tend to have more bugs when I use MPASM on anything else but the 18Fxxx chips....
    Any advice welcome...
    Squib
    To be honnest i never use PM, so i don't understand when you say
    If you don't use any assembler lines/macro/feature/etc etc there's no real advantage between PM/MPASM. MPASM should compile as fast as PM, but it load that little GUI... hence why it may appear to be a bit more slow.
    You can still open PM.TXT and MPASM PDF and compare both features.
    PM and MPASM syntax are a bit different, so why using 2 syntax when only one is more powerfull anyway. But again, if you just use PBP syntax/command set, it doesn't make any difference... or just in the CONFIG fuse syntax... big deal.
    mmm... sure i still forgot something...
    Oct 2003
    Australia
    mr E,
    Your probably right, it's the config fuse settings that most likely generate the errors when coding...
    I'll try and use MPASM for the time being and see how that pans out.
    Big deal.
    BTW, I downloaded your picmultical program from your revamped site (very nice). I found it very useful.
    It would be nice if you could add a "copy register settings to clipboard" button for the PWM calcultor with a check box to select the appropriate prescaler option.
    Cheers
    Squib
  1. Warning (and other Compilation Error) Messages
    Last Post: - 9th September 2009, 02:29
  2. Moved from PM to MPASM and have fuse definition problems
    Last Post: - 26th November 2008, 23:27
  3. erratic behavior when using MPASM vs. PM
    By cool_justin in forum mel PIC BASIC Pro
    Last Post: - 8th June 2006, 02:08
  4. Converting to MPASM
    Last Post: - 4th November 2005, 02:35
  5. PM assembler versus MPAsm
    By bwarb in forum mel PIC BASIC Pro
    Last Post: - 16th August 2005, 17:14
