rfPIC Serin problem
Results 1 to 40 of 53
    Jun 2006
    Hi
    U have not included modedefs.bas in ur program.is that an issue?
    I did that but to no avail.
    maybe config fuses are causing something.they seem ok.they are as under when i read them using PICkit 1 software:
    12F675
    config word:0x31D4
    osccal: 0x3480
    bandgap: 0x3000
    12F676
    config word:0x31C4
    osccal: 0x3440
    bandgap: 0x3000
    Nov 2007
    Default rfrxd0420
    Hi there,
    I've altered the receiver_demo program to suit my application. - I took in the data from rfRxd0420 drom RC2 and try to take it out serially from RC0 of the pic16f676 so that I can
    probe the data transmitted.
    Currently, I'm simulating the program using MPLAB IDE. Pardon me if I'm wrong.
    The receive_demo program that I understand, will check for header. But,
    it does says that if the data is high before 6ms, therefore the header is valid.
    What if the data is also 'LOW'?
    I'm actually having problems with simulation coz it does not want to
    come out of the loop - unless I put '1' in between.
    When it came out of the loop, I should be able to record that and then output that
    to the RC0 but it seems that the program didn't even jump to search for a guard time,
    instead it continue the process to find for high or low pulse.
    I just altered the receive demo of the dev kit. Can anyone help me please?
    Or do you suggest a better way to simulate this program?
    MAIN
    call CLOCK ; to update TRMLOW and TMRHIGH
    ; TMRLOW ~=4us TMRHIGH ~=1ms
    movlw HIGH STATEM
    movwf PCLATH
    movf STATECNTR, W ; Mask out the high order bits of
    andlw B'00001111' ; STATECNTR (a noise guard)
    addwf PCL, F ; The program clock (PCL) is incre-
    STATEM
    ; check for possible start of data stream
    goto BEGIN ; mented by STATECNTR in order
    goto BEGIN1 ; to go to the appropiate routine
    goto HEADER ; header is being ignored
    goto HEADER1 ; just count up the time and then takes the data
    goto HIGHPLSE ; times the width of Hi Pulse
    goto LOWPULSE
    goto RECORD ; record the 8 byte data
    goto WAIT4END ; wait for guard time to be greater than 8ms
    goto FIRST0 ; check whether DATA0 of bit 0 is 0 or 1
    call SENDOUT ; to send out the serial data out through portc pin 0
    goto RESET ; These RESET commands correct
    goto RESET ; erroneous values of STATECNTR
    goto RESET ; not caught by the mask above.
    goto RESET
    goto RESET
    goto RESET
    Nov 2007
    from the demo program, they used ASK modulation which use NRZ format modulation.
    in this format, when the input is zero it would give you a pulse of 110 while if the input is one, it would give pulse 011, which means it will still give you pulse high for whichever input.
    Nov 2007
    im still experiencing this overflow stack error message..
    ive tried to change all goto to call instruction
    put return for every subroutine..but still it doesnot work
    can anyone help me
    i pasted my full program below
    ;nur azrin hilmi
    ;gdp 17-telemetr
        LIST   		P=RF675K       ; list directive to define processor
     	#include    <RF675K.INC>  ; processor specific variable definitions
    ;**************define variables*********************************
    	#define	sensor	GPIO, 1
    	#define txd     GPIO, 2             ; (Output) Transmit Data
    	#define pb3     GPIO, 3             ; (Input Only) Push button switch GP3
    	#define pb4     GPIO, 4             ; (Input) Push button switch GP4
    	#define rfena   GPIO, 5             ; (Output) RF Enable
     	; GPIO Pins =    xx543210
    ;	#define gptris b'00011011'
    	#define TGUARD  d'5'
    	#define exor 	b'00000000'
    	#define	total d'8'
    ;	#define	rtime d'5'
    	org  0x00
    	goto initialize
    	org  0x004
    	movwf	w_temp
    	swapf	STATUS,W
    	bcf		STATUS, 5		;select bank 0
    	movwf	status_temp		;save status register
    ;	interrupt service routine (ISR)
    ;   interrupt on change on pin of gpio
    	movfw	GPIO
    	bcf		INTCON,0
    	swapf	status_temp,w	;set bank into original state
    	movwf	STATUS
    	swapf	w_temp,F
    	swapf	w_temp,W
    	retfie
    WaitxTE
            movwf   Count2      ; [1]
    waitxlp
            movlw   D'30'       ; [1]
            movwf   Count       ; [1]
    wait400lp
          nop                 ; [1]
          nop                 ; [1]
        decfsz  Count,F     ; [1]
        goto    wait400lp  ; [2]
    ;                         79 x 5 = 395us
         decfsz  Count2,F    ; [1]
        goto    waitxlp    ; [2]
         retlw   0           ; [2]
    ;                       total 2 (call) + W x (395 + 5) + 2 (return)
    ;                       w = 1 -> 406us @4MHz
    ;                       w = 2 -> 806us @4MHz
    ;initialize pic
    initialize
    ;clearing all ports
    	CLRF	nobit
    	CLRF	nobit2
    	clrf	input
    	clrf	store
    	clrf	rotateright
    	clrf	Count
    	clrf	Count2
    	clrf	ltime
    	clrf	rtime
    ;disable global interrupts during initialization
    	bcf     INTCON,7
    ;calibrating the internal oscillator
    ;	bsf     STATUS,5		;select bank 1
    	call	0x3FF
    	movwf	OSCCAL
    ;	bcf		STATUS,5
    ;turn off the comparator
    	bsf		STATUS,5
    	clrf 	ANSEL			; clear ansel register
    	bcf		STATUS,5
    	clrf 	GPIO			; initialize General Purpose Input Output to 0
    ;setting gpio register to the cosrresponding io pin
    	bsf 	STATUS,5
    	bsf		TRISIO,0
    	bsf		TRISIO,1
    	bsf		TRISIO,4
    	bcf		TRISIO,2
    	bCf		TRISIO,5
    	bcf     STATUS,5		;select bank 0
    ;set bit 0:2 at register cmcon	;setting gp2 as digital output |offkan comparator
    	bsf		STATUS,5
    	bsf		CMCON,0
    	bsf		CMCON,1
    	bsf		CMCON,2
    	BCF		STATUS,5
    ; VRCON	register ; CVref circuit powered down,no Idd drain
    	bsf		STATUS,5
    	bcf		VRCON, 7
    	bcf		STATUS,5
    ;****timer1 module gate control**********************************
    ; disabling timer1
    	bsf		STATUS, 5		; select Bank 1
    	movlw   b'01000100'		; disable TIMER1
    	movwf	T1CON		;
    	bcf		STATUS, 5		; select Bank 0
    ;weak pull-up register (wpu)
    ;each pull-up is automatically turned off when the pin is configured as an output
    	bsf     STATUS,5
    	movlw	b'00010000'
    	movwf	WPU
    	bcf     STATUS,5
    ;***************set pin for config_address regsiter
    ;OPTION Register
    ;   OPTION_REG contains control bits to configure:
    ;   Weak pull-ups on GPIO (see also WPU Register above)
    ;   External GP2/INT interrupt
    ;   TMR0
    ;   TMR0/WDT prescaler
            bsf     STATUS,5	         	; ---- Select Bank 1 -----
            bcf     OPTION_REG, NOT_GPPU  	; GPIO pull-ups: enabled
            bsf     OPTION_REG, INTEDG  	; Interrupt Edge: on rising edge of GP2/INT pin
            bcf     OPTION_REG, T0CS    	; TMR0 Clock Source: internal instruction cycle (CLKOUT)
            bcf     OPTION_REG, T0SE    	; TMR0 Source Edge: increment low-to-high transition on GP2/T0CKI pin
            bcf     OPTION_REG, 3     		; Prescaler Assignment: assigned to TIMER0
            ; TMR0 Prescaler Rate: 1:2
            bcf     OPTION_REG, 2     		; Prescaler Rate Select bit 2
            bcf     OPTION_REG, 1     		; Prescaler Rate Select bit 1
            bcf     OPTION_REG, 0     		; Prescaler Rate Select bit 0
            bcf    STATUS, 5         		; ---- Select Bank 0 -----
    ;interrupt on-change register
    	bsf     STATUS,5
    	movlw  	b'00011011'		;enable global interrupts in order for the individual pin to be configured(kalo switch
    	movwf	IOC
    	movlw	b'00000000'		;peripheral interrupt register; disable
    	movwf 	PIE1
    	bcf    STATUS,5
    	movlw	b'00001000'		;enable interrupt control register
    	movwf	INTCON
    ;MAIN PROGRAM
    ;*****************************************************************8
    MAIN
            bsf     INTCON,7  ; enable global interrupts
    	;	bsf		rfena     ; enable	transmitter
    		call    BITCHECK
    ;CHECK INPUT
    BITCHECK
    	btfsc	nobit2,3
    	goto	TRANSMIT
    	movfw	GPIO
    	movwf	input
    	incf	nobit2,f
    	movfw	nobit2
    	movwf	nobit
    	btfsc	nobit2,2
    	goto	checkleft	;for bit number 4,5,6,7
    	goto	checkright	;for bit number 1,2,3,8
    checkleft
    	btfsc	nobit2,1
    	goto	rleft
    	btfsc	nobit2,0
    	goto	bit5
    	goto	rright1
    	return;
    checkright
    	btfsc	nobit2,3
    	goto	rleft
    	return;
    rright1
    	movlw	d'5'
    	movwf	rtime
    	return;
    rright
    	decf	rtime,f
    	decfsz	nobit
    	goto	rright
    ;	movwf	rtime
    rotater
    	rrf		input,f
    	decfsz	rtime
    	goto	rotater
    	movfw	input
    	xorwf	store,w
    	movwf	store
    	goto    BITCHECK
    	return;
    bit5
    	movfw	input
    	xorwf	store,w
    	movwf	store
    	goto	BITCHECK
    	return;
    rleft
    	movfw	nobit
    	movwf	ltime
    	decf	ltime
    	decf	ltime
    	decf	ltime
    	decf	ltime
    	decf	ltime
    rotatel
    	rlf		input,f
    	decfsz	ltime
    	goto	rotatel
    	movfw	input
    	xorwf	store,w
    	movwf	store
    	goto    BITCHECK
        return;
    TRANSMIT
    		bsf		GPIO,5
    ; send preamble (50% duty cycle)
    Preamble					;send 16 bit
          movlw   d'16'
          movwf   BitCount          ; init number of preamble bits
    PreL
            bsf     txd             ; ON
            movlw	1
    		call    WaitxTE           ; delay
            bcf     txd             ; OFF
           	movlw	1
            decfsz  BitCount,F      ; loop
            goto    PreL
    ; sync pause
    TXloop
           movlw d'10'
    	   call    WaitxTE         ; Theader = 10 x Te
    ; send 72 bit pattern
            movlw   store            ; lsb first
            movwf   FSR
    TXNextByte
          movlw   D'8'
          movwf   BitCount
    TXNextBit
            rrf     INDF,W           ; 8 bit rotate | rotate right f through carry
            rrf     INDF,F           ; Carry contain lsb
            BC      ONE				 ; branch on carry | goto ONE if bit is set
    ZERO    					;wave pattern if the bit is zero
            movlw   2               ;
    	    movwf   TimeHi          ;   +---+---+   +--
            movlw   1               ;   |       |   |
       		movwf   TimeLo          ;---+       +---+
            goto    Trasm_BIT       ;   |  2Te   Te |
    ONE							;wave pattern if the bit is one
            movlw   1              	;
            movwf   TimeHi          ;   +---+       +--
            movlw   2               ;   |   |       |
            movwf   TimeLo          ;---+   +---+---+
                                    ;   | Te   2Te  |
    Trasm_BIT
            bsf     txd             ; ON
            movf    TimeHi,W
            call    WaitxTE
            bcf     txd             ; OFF
            movf    TimeLo,W
            call    WaitxTE
           	decfsz  BitCount,F
            goto    TXNextBit       ; loop on bits
    ; guard time
            movlw   TGUARD
            call    WaitxTE
           org     0x3ff
           retlw    0x80
            end                         ; end of program directive
    Nov 2007
    Default help with pic12f676
    I managed to work through the receiving and process the data and store it to DATA0.
    What I can't do now is sending out serially the 8 bit DATA0 to
    the pin SER_OUT(which happens to be PIN RC0).
    I've tried to copy DATA0 to PORTC (in RECORD2) but since PORTC is only 6 bit, the data is not out correctly. Can anyone help me please?
    ; RECORD
    ; Records each bit as it comes in from the data stream.
    ; Input Variables:
    ; RXDATA
    ; Output Variables: 1 bytes of the 8 bit data read from sensor
    ; DATA0
    RECORD
    movf HIGHWDTH, W
    subwf LOWWDTH, W ; The state of the carry bit after
    ; this operation reflects the data
    ; logic. This is then rotated
    ; into the storage bytes.
    rrf DATA0, F ; the only data to be processed
    movlw HIGHP ; 0x04 to STATECNTR
    movwf STATECNTR
    decfsz BITCNTR, F ; If the bitcntr is = 0 , skip next instruction
    goto MAIN
    ; set to count for 1 data - record 1 byte of data bit by bit
    movlw D'1' ; Starting here and including RECORD1
    movwf COUNTR ; a check is made to make sure that
    movlw DATA0 ; the data is not composed entirely
    movwf FSR ; of 1s.
    ;FSR is the register to store the DATA0
    RECORD1 ; this is the procedure of indirect addressing
    movlw 0xFF
    xorwf INDF, W ; Use indirect referencing to point to
    btfss STATUS, Z ; DATA0 on subsequent loops
    goto RECORD2 ; in RECORD1.
    incf FSR, F
    decfsz COUNTR, F
    goto RECORD1
    goto RESTART
    RECORD2
    movlw WAIT
    movwf STATECNTR ; Make state WAIT4END
    movfw DATA0 ; copy DATA0 to PORTC
    movwf PORTC ; want to send data out serially
    ; bsf SER_OUT ; pin RC5 to observe the processed output
    goto MAIN
    medusa2584,
    Recheck your code flow.
    You're still trying to RETURN from GOTO in various places.
    And (I'm not even sure if it's possible in MPLAB) are you getting stack OVERFLOW errors or stack UNDERFLOW errors? If getting UNDERFLOW is possible, that's what I'd say you're getting.
    Nov 2007
    thanks skimask. i solved the the underflow and overflow program. however, i got a new problem.
    when i tested my program with rfpic12f675, and put probe at gp2 and gp5. the output is similar with what i simulated in mplab sim. there is preamble, header, and data bits. however, there is no change of output displayed on the oscilloscope even i dont supply any input to the transmitter. any suggestion why this happened?
    the output always showed data bit of 1111 0111 which is weird since i sont supply any input to the system.
    any suggestion anyone?
    T.Jackson's Avatar
    T.Jackson Guest
    medusa2584,
    Hello skimask,
    I'd like to take this opportunity to welcome you back to the forum. I do hope that your stay will be a long, pleasant & fruitful one. Everyone deserves a second chance
    Nov 2007
    I was simulating my program and did not even finish running everything - my MPlab just suddenly close itself with a window Microsoft is checking the problem.
    Does anyone know why? Is that because of my Vista or because of the bug in the
    new version MPLab IDe 8?
    Hello skimask,
    2nd chance?
    2nd chance at what?
    Did I lose my first chance at something?
    Did you have something to do with afford me a second chance at whatever it is?
    Did I go somewhere else that I needed to come back?
  1. Serin Problem with 12F629/PBP
    By Flyingms in forum mel PIC BASIC Pro
    Last Post: - 9th March 2009, 15:59
  2. Serin Problem 16f819
    By jjohannson in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2007, 23:50
  3. Serin serout problem
    Last Post: - 6th February 2007, 05:25
  4. Problem with PBP interrupt and Serin, please help
    By rgregor in forum mel PIC BASIC
    Last Post: - 22nd August 2006, 20:02
  5. serout and serin problem
    Last Post: - 11th April 2006, 20:44
