Cannot write whole 16 characters using 16x1 lcd
Results 1 to 7 of 7
    Dec 2005
    So Cal and loving it
    Could be C0 or 88.
    If not you will have to make a small program to cycle through the different addresses until you find the 9 char address.
    Paul
    | PBP 2.47/2.50 | MCS+ 3.0.0.5 | U2 Prog | Vista x64 | NO SLEEP!!!!!!! |
    Talking Humour ...
    Vista 32 | NO SLEEP!!!!!!!
    LOL !!!
    Dec 2005
    LOL,
    There seem to be lots of people that do not get on with Vista, but my new laptop came with Vista and it has been very stable sytem so far.
    Just lucky I quess.....
    Paul
    Bombay, India
    Ok, here it is - just so you can sleep
    /* Write ASCIIZ String to LCD at specified row and column from *Buffer */
    void LCD_puts(byte code *Buffer){
    byte x;
    	LcdColumn = 0;
    	LCD_write(0x80,CMD);
      while (x = *Buffer++)	{
    		LCD_write(x,DATA);
    		if (LcdColumn++ == 7) LCD_write(0xc0,CMD);
    CMD is the command register of the LCD, DATA is the data register. Addresses are 0x80 and 0xc0
    JF
    Sep 2007
    Default Wish it as full 16x1 instead of running 8x2 program.
    I had it working before anyone posted my question. I using code what was used for 8x2 and 16x2, it filled out correctly but uses more codes to do this instead of regular 16x2.
  1. Play with LCD on PICDEM
  2. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 14:19
  3. Changing declared variables names on the fly
    Last Post: - 16th December 2006, 06:34
  4. LCD 16 characters inline: only first 8 work
    By Mugel in forum mel PIC BASIC Pro
    Last Post: - 20th October 2006, 22:07
  5. 8 Characters only on 16x1 LCD
    Last Post: - 12th February 2006, 07:32
