Cannot write whole 16 characters using 16x1 lcd
Results 1 to 7 of 7
    Sep 2007
    Unhappy Cannot write whole 16 characters using 16x1 lcd
    I have no problem with 16x2 LCD but when I swap to 16x1 unit, cannot do whole 16 character fill in and cuts off after 8th charactor on a single line.
    Any solution?
    Code: Default for 16x2,
    define lcd_dreg portc
    define lcd_dbit 0
    define lcd_rsreg portc
    define lcd_rsbit 4
    define lcd_ereg portc
    define lcd_ebit 5
    define lcd_bits 4
    define lcd_lines 2
    define lcd_commandus 2000
    define lcd_dataus 44
    Example
    LCDOUT $FE,1,"Hello World" ' works fine for 16x2
    for 16x1 unit, this is what occurs using 16x1 displayed as Hello Wo, where's the "rld", cuts off after 8th character.
    using Lumex LCM-S01601DSF.
    Bombay, India
    The 16x1 LCD is organized as 8x2 lines display. So, you need to write the 2nd 8 characters as line 2. I am not sure of the addresses though right now.
    Jerson
    Dec 2005
    So Cal and loving it
    Could be C0 or 88.
    If not you will have to make a small program to cycle through the different addresses until you find the 9 char address.
    Paul
    | PBP 2.47/2.50 | MCS+ 3.0.0.5 | U2 Prog | Vista x64 | NO SLEEP!!!!!!! |
    Talking Humour ...
    Vista 32 | NO SLEEP!!!!!!!
    LOL !!!
    Dec 2005
    LOL,
    There seem to be lots of people that do not get on with Vista, but my new laptop came with Vista and it has been very stable sytem so far.
    Just lucky I quess.....
    Paul
    Bombay, India
    Ok, here it is - just so you can sleep
    /* Write ASCIIZ String to LCD at specified row and column from *Buffer */
    void LCD_puts(byte code *Buffer){
    byte x;
    	LcdColumn = 0;
    	LCD_write(0x80,CMD);
      while (x = *Buffer++)	{
    		LCD_write(x,DATA);
    		if (LcdColumn++ == 7) LCD_write(0xc0,CMD);
    CMD is the command register of the LCD, DATA is the data register. Addresses are 0x80 and 0xc0
    JF
  1. Play with LCD on PICDEM
  2. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 14:19
  3. Changing declared variables names on the fly
    Last Post: - 16th December 2006, 06:34
  4. LCD 16 characters inline: only first 8 work
    By Mugel in forum mel PIC BASIC Pro
    Last Post: - 20th October 2006, 22:07
  5. 8 Characters only on 16x1 LCD
    Last Post: - 12th February 2006, 07:32
