This is not the same one Jerson recommended but should work.
http://www.allelectronics.com/cgi-bi...REGISTER_.html
$7.00 shipping ground no matter the size of order.
You said you have seven pins...register takes 8 inputs and uses three on the PIC. Now you have four left. Use one for the left over switch, now you have three pins left.BTW this is a 9 position dipswitch not 8.![]()
i second the Voltage divider option too. Look at the Microchip appnote bellow
