self diagnostic problem 16F819
Results 1 to 6 of 6
    wilfrieds's Avatar
    wilfrieds Guest
    Post self diagnostic problem 16F819
    Hello there
    I'm working on a "yellow metal" LCD display dashboard, it took me a very very long time so far ( years ) and is finally ready for a test ride.
    In order to improve on the hardware diagnostic ( broken wire warning etc ...)
    I still remain with a problem that has me shaking my head.
    When the microcontroller is started without a connection to the tempval = adin 1
    see tempcalc: then it does not display the results from adin 2 and adin3
    namely the battery voltage and the oil pressure warning light.
    I would like to improve the program so it can diagnose and display all hardware problems
    as much as possible
    tempcalc:
    tempval = Adin 1 ' Read portA.1 to tempval
    If tempval > 1000 then goto tf ' faulty connection
    If tempval > 415 then goto cold
    if tempval > 320 then goto calc1
    If tempval > 241 then goto calc2
    If tempval > 157 then goto calc3
    If tempval > 112 then goto calc4
    If tempval < 113 then goto tf ' faulty wiring or sender - short to ground.
    the program and hardware connections:
    www.skidloaders.co.za/pic/LCDDv21.bas
    a picture when all goes well
    www.skidloaders.co.za/pic/LCDdash1.JPG
    a picture when wire of temperature gauge is not connected
    www.skidloaders.co.za/pic/LCDdash2.JPG
    It's getting late so - to all - goodnight
    Wilfried
    Try something like
    If tempval = 0 then go someplace else
    Or do an IF THEN ELSE at the end of the tempval block.
    It looks like the program is stuck waiting on "tempval".
    after all the calc routines theres goto tempdisp but for the tf routine you have goto loop. never gets to temp display.
    wilfrieds's Avatar
    wilfrieds Guest
    Smile
    Thanks guys
    Talking Lol !!!
    Vade Retro ... Satanas !!!
    " written in proton+ 2 by Wilfried Smekens "
    What does proton+ 2 really mean ???
    wilfrieds's Avatar
    wilfrieds Guest
    Cool protron+ 2
    Bonjour Alain
    Proton Plus version 2
    Similar Pic Basic pro language as microcode. ??
    I actually bought microcode in the belief that is was the newer version of Proton.
    I still have not used it but will probably will once the 18F series become more used.
    Kind regards
    Very wet South Africa. ( we needed the rain real badly )
    Wilfried
  1. USART Problem , but don't know where, in pc? or in PIC?
  2. Pulsin 16F819 problem
    By rekcahlaer in forum mel PIC BASIC Pro
    Last Post: - 11th April 2007, 14:52
  3. Serin Problem 16f819
    By jjohannson in forum mel PIC BASIC Pro
    Last Post: - 22nd March 2007, 23:50
  4. PIC 16F819 Turn-On Problem
    By Dick Ivers in forum mel PIC BASIC Pro
    Last Post: - 13th September 2005, 23:12
  5. Rb1 Problem On A 16f819..
    By Calco in forum mel PIC BASIC Pro
    Last Post: - 14th April 2004, 16:09
