cant get my Lcd to work using Pic18f452
Results 1 to 14 of 14
    Default cant get my Lcd to work using Pic18f452
    i am new to this so please help me out in anyway. I trying to get my code to work and so far i am getting just black boxes on the lcd display..
    i also get this error when compileing "config has been deprecated for 18f devices
    define LCD_DREG PORTB ' set LCD Data port
    define LCD_DBIT 4 ' set starting data bit
    define LCD_RSREG PORTB ' set LCD registers
    define LCD_RSBIT 2 ' set LCD register select bit
    define LCD_EREG PORTB ' set LCD enable port
    define LCD_EBIT 3 ' set LCD enable bit
    DEFINE LCD_BITS 4 ' set LCD bus size
    define LCD_LINES 4 ' set number of lines on LCD
    define LCD_COMMANDUS 2000 ' set command delay time in us
    define LCD_DATAUS 50 ' set data delay time in us
    '''Variables'''
    v1 var word 'Variable where digital value will be stored
    '''TRIS registers'''
    trisb = %00000000 'Set PORTB pins as outputs
    ' This 'INCLUDE' routine is use to read a matrix keypad.
    ' Allow to use various keypad format
    ' Allow to place the keypad ROW and COL on different PORT.
    ' The routine set TRIS register for you
    ' How to use it
    ' 1. Include the file
    ' write
    ' INCLUDE "KeyPad.bas"
    ' somewhere in your code.. after TRIS setting and before MAIN loop
    ' 2. Call the Keypad routine by one or the other method bellow
    ' 1. By calling the macro
    ' @ READKEYPAD _YourVar
    ' result store in 'YourVar' wich must be defined as a BYTE sized variable
    ' 2. By using GOSUB
    ' GOSUB KeypadScan
    ' result is store in 'Key' Variable
    ' Specific DEFINE
    ' The defaults setings are
    ' 1. Keypad ROW are connected to PORTB<3:0>
    ' 2. Keypad COL are connected to PORTB<7:4>
    ' 3. Debounce delay = 200 mSec
    ' 4. No auto-repeat
    ' 5. Keypad type 4X4
    ' If you decide to change default settings, here's the DEFINEs list
    ' DEFINE KEYPAD_ROW 4 ' 4 ROW keypad
    ' DEFINE KEYPAD_ROW_PORT PORTB ' ROW port = PORTB
    ' DEFINE KEYPAD_ROW_BIT 4 ' ROW0 = PORTB.4
    ' DEFINE KEYPAD_COL 4 ' 4 COL keypad
    ' DEFINE KEYPAD_COL_PORT PORTB ' COL port = PORTB
    ' DEFINE KEYPAD_COL_BIT 0 ' COL0 = PORTB.0
    ' DEFINE KEYPAD_DEBOUNCEMS 200 ' debounce delay = 200 mSec
    ' DEFINE KEYPAD_AUTOREPEAT 1 ' use auto-repeat feature
    ' When using the auto-repeat feature, the delay is the debounce delay (DEBOUNCEMS)
    ' Hardware Connection
    ' 1. Column bits must have Pull-up resistor attach to VCC
    ' 2. ROW bits must be connected in serie with resistor.
    ' Results
    ' Results are always set the same way, even with different keypad type
    ' 3X4
    ' Col0 Col1 Col2 Col3
    ' 1 2 3 4 Row0
    ' 5 6 7 8 Row1
    ' 9 10 11 12 Row2
    ' 6X5
    ' Col0 Col1 Col2 Col3 Col4
    ' 1 2 3 4 5 Row0
    ' 6 7 8 9 10 Row1
    ' 11 12 13 14 15 Row2
    ' 16 17 18 19 20 Row3
    ' 21 22 23 24 25 Row4
    ' 26 27 28 29 30 Row5
    asm
    errorlevel 0,-207 ; Disable 'found opcode after...' warning
    ; Macro Definition
    READKEYPAD macro KeyVar
    L?CALL _KeypadScan
    MOVE?BB _Key,KeyVar
    ; Default settings
    KB_ROW = 4 ; 4 ROW keypad
    KB_ROW_PORT = PORTC ; Keypad ROW on PORTC
    KB_ROW_BIT = 0 ; ROW0 = PORTB.0
    KB_COL = 4 ; 4 COL keypad
    KB_COL_PORT = PORTC ; Keypad Col on PORTC
    KB_COL_BIT = 4 ; COL0 = PORTB.4
    DebounceDelay = d'200' ; debounce delay 200mSec
    ; Software Definition
    ; Keypad type definition
    ifdef KEYPAD_ROW
    KB_ROW = KEYPAD_ROW ; Assign amount of ROW
    ifdef KEYPAD_COL
    KB_COL = KEYPAD_COL ; Assign amount of COL
    ; ROW pins assignement
    ifdef KEYPAD_ROW_PORT
    KB_ROW_PORT = KEYPAD_ROW_PORT ; Assign ROW to user selected PORT
    ifdef KEYPAD_ROW_BIT
    KB_ROW_BIT = KEYPAD_ROW_BIT ; Assign ROW0 to user selected BIT
    ; COLUMN pins assignement
    ifdef KEYPAD_COL_PORT
    KB_COL_PORT = KEYPAD_COL_PORT ; Assign COL to user selected PORT
    ifdef KEYPAD_COL_BIT
    KB_COL_BIT = KEYPAD_COL_BIT ; Assign COL0 to user selected BIT
    ; Keypad debounce delay
    ifdef KEYPAD_DEBOUNCEMS
    DebounceDelay=KEYPAD_DEBOUNCEMS
    endasm
    ' Variable definition
    KB_ROW_PORT VAR BYTE EXT ' ROW port
    KB_COL_PORT VAR BYTE EXT ' COL port
    Col var byte '
    Row var byte '
    RowBit var byte '
    Key var byte ' result of scanned key
    KeyTemp var byte '
    ' Constant definition
    KeyMask con EXT ' Key mask when reading PORT
    InitialState con EXT ' initial ROW PORT value
    KB_ROW CON EXT ' # row
    KB_COL CON EXT ' # column
    KB_ROW_BIT CON EXT ' ROW0 bit
    KB_COL_BIT CON EXT ' COL0 bit
    DebounceDelay CON EXT ' Debounce delay, also Auto-Repeat delay if defined
    asm
    KeyMask = b'11111111' >> (8-KB_COL) ; use to keep only COL bits
    InitialState=b'00001111' << KB_ROW_BIT ; Initial state of ROW column bits
    endasm
    start:
    Pause 1500
    lcdout $fe, 1 ' clear display
    lcdout $fe, $80 ' move cursor to begining of line
    lcdout " Welcome to JDA Tech "
    lcdout $fe, $C0
    Lcdout " Wireless Sleep Apnea " ' output the following
    lcdout $fe, $94
    LCDout " Monitor"
    pause 3000
    Main: ' Operations todo
    Lcdout $fe, 1
    lcdout $fe, $80
    lcdout " Choose an Option"
    pause 3000
    lcdout $fe,1
    lcdout $fe, $80
    lcdout "1 :Start to Record"
    lcdout $fe, $C0
    lcdout "2 :Stop " ' display on LCD
    pause 10000
    lcdout $fe, 1
    lcdout $fe, $80
    lcdout "3: Send Data to RS-232"
    lcdout $fe, $C0
    Lcdout "4: Last Reading Percentage"
    gosub Keypadscan
    If (key = 1) then
    lcdout $fe, $D4, #key
    Goto Record
    IF (key = 2) then
    Pause 100
    Stop
    Endif
    IF ( key = 3 ) Then
    Pause 100
    GOTO Send
    If ( key = 5 ) then
    Pause 100
    Goto Percentage
    IF ( key > 5 ) then
    lcdout $fe, $C0
    Lcdout "Invalid Choice"
    GOTO main
    As far as the black boxes go, do you have a POT wired as a voltage divider with the wiper going to the contrast pin of the LCD?
    Look here for the new config.
    http://www.picbasic.co.uk/forum/show...ost13087#post6
    Black square could also mean that the LCD initialization haven't been done properly. Now why... maybe because the LVP mode is still enable, hence RB5 can't be used as a standard I/O. Make sure you disable it in your config fuses.
    The deprecated stuff is just a warning. you can disable it
    @ ERRORLEVEL -230
    in your code or modify the 18F452.inc file in your PBP folder.
            NOLIST
        ifdef PM_USED
            LIST
            "Error: PM does not support this device.  Use MPASM."
            NOLIST
            LIST
            LIST p = 18F452, r = dec, w = -311, w = -230, f = inhx32
            INCLUDE "P18F452.INC"   ; MPASM  Header
            __CONFIG    _CONFIG1H, _OSCS_OFF_1H & _XT_OSC_1H
            __CONFIG    _CONFIG2H, _WDT_ON_2H & _WDTPS_128_2H
            __CONFIG    _CONFIG4L, _LVP_OFF_4L
            NOLIST
            LIST
    EEPROM_START	EQU	0F00000h
    BLOCK_SIZE	EQU	8
    This have been corrected in V2.47.
    Default disableing RB5
    thanks for the info.. one question on that though would it be that i would have to disable it from the trisb ?
    Trisb be will set the I/O as an input or output. LCDOUT will automatically do it for you as well, but even with it, if you didn't disable the LVP mode, it will not work.
    Same rules apply with ADC, Comparator etc etc.
    Default follow up
    i could not access the inc file due to access is denied due to school computer. So i tried config 4l by the use of config4l= 0x81
    ; Default settings
    CONFIG4L =0x81
    Apr 2007
    Southern Ontario
    I had the same problem and it drove me crazy untill I turned the lcd off an noticed for a spit second my message appear. Really look at that contrast pin and make sure you can fade the boxes on and off. This might not be the solution but it was in my case.
    Snap
    Beer is proof that God loves us and wants us to be happy.
  1. Pic18f452 with 20x4 LCD Help
    By djmachine in forum mel PIC BASIC Pro
    Last Post: - 6th November 2008, 22:43
  2. Play with LCD on PICDEM
  3. Need help with LCD number display.
  4. Why doesn't my code for 18f452 work on 18f252?
    By senojlr in forum mel PIC BASIC Pro
    Last Post: - 23rd December 2005, 02:42
  5. having problems with Hantronix 20x4 lcd
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 12:22
