Elevator Display
Results 1 to 2 of 2
    Question Elevator Display
    Can somebody guide me with an example for my project, I'm using a keypad and 2 7segments, i would like to press any number on the keypad and display the number on the 7segments. Something like the display on the elevator
    Thanks.
    Mentor, Ohio
    Smile
    Hello Apprentice,
    Mister E has posted a keypad program on this forum called Matrix Keypad routine in the CODE EXAMPLES section. That will get you started with the keypad part. Then on the MELABS website is an example called 7segement.pbp that will show you how to use led displays. There are also many posts regarding the use of LCD displays also. Using this information should get the juices flowing to get you what you want. There probably are many more examples of using keypads and 7 segment displays on one of the forums here but you can use the search feature to find them.
    HTH,
    BobK
