Second serial port access ( Hserin2 )
Results 1 to 6 of 6
    I have not had the need to use HSERIN2/HSEROUT2, but I would assume it is like the manual says---
    Both AUSART and EUSART are pretty much the same thing.
    The "E" stands for enhanced with some bells and whistles.
    This might help understand the difference.
    http://ww1.microchip.com/downloads/e...tes/00944A.pdf
    Jun 2004
    Thank you very much Mackrackit.
    I know the difference between AUSART and EUSART. I was asking regarding the PBP compatibility side. Although it is supposed to work as described in the manual I red some complains from some users ( the posts does not exist anymore ) where they were stating that accessing the 2nd port does not work in PBP.
    I will give it a try .
    Thank you for your time,
    It's been a long time, but I've used HSERIN2 on an 8720, and it worked as advertised.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jun 2004
    Well, this is very good news.
    Thank you , Bruce
  1. HSERIN2 not working on PIC18F97J60 ???
    By mikebar in forum Serial
    Last Post: - 4th May 2008, 15:20
  2. interfacing to the pc serial port
    By kelangfei in forum General
    Last Post: - 7th October 2007, 22:35
  3. Microcontroller with 2 way paging application problem
  4. serial port control relay
    By win_832001 in forum mel PIC BASIC Pro
    Last Post: - 23rd June 2006, 23:56
  5. Replies: 2
    Last Post: - 28th April 2006, 12:10
