Averaging 16 bit values without using 32 bit math
Results 1 to 3 of 3
    Jan 2007
    Brazil
    Default Averaging 16 bit values without using 32 bit math
    Hello everyone..
    I am trying keep a running average of the last 400 samples of signal. This signal's range is 500~1200. Is Darrel's Taylor Running Average routine (thanks Darrel) going to work? Should I increase the range of my signal, for example, for 10000~24000? ( x 20)
    Thanks in advance!
    Regards..
    Sylvio,
    That averaging routine doesn't work so well with LARGE sample sizes.
    Scaling the values up will help some, but it will still suffer on the low end.
    A couple years ago, there was another guy that wanted to average 8,000 samples.
    I wrote the attached program for him, and like normal, never heard from him again.
    Usually that means it worked.
    No guarantees, but you might give it a try...
    Hangover, Germany
    Talking
    Maybe you can use 256 samples.
    You only have to add the highbytes of the samples!
    (a1+a2+...+a256)/256 is the same as: a1/256+a2/256+...+a256/256
    The problem is rounding! I would add the MSB of the low-bytes and divide this sum by 2 and add it to the first result.
    Just think a little about it !
    ($1270+$1280+$1290+...)/256 = $12+$12+$12+...
    and: (0+1+1+...)/2=1.0
    so you get: $36+1.0= 55 !!!
  1. Darrel's latest 16 bit averaging routine?
    Last Post: - 17th October 2009, 02:57
  2. Funny PULSIN values: what is going on???
    Last Post: - 30th April 2008, 09:02
  3. 32 bit math
    By fnovau in forum General
    Last Post: - 13th February 2008, 00:55
  4. PIC18Fxx math 24 & 32 bit
    By ronsimpson in forum mel PIC BASIC Pro
    Last Post: - 2nd December 2006, 13:52
  5. 32 bit math
    Last Post: - 28th August 2006, 14:34
