How to apply waiting time for capture data from serial port
Results 1 to 5 of 5
    Oct 2007
    Default How to apply waiting time for capture data from serial port
    I want capture hex code (FE CA) from another pic using serin command.
    B1 = First Byte
    B2 = Second Byte
    command for Sending : Serout TX_t,t9600,[$FE,$CA]
    command for capture : Serin RX_r,t9600,B1
    Serin RX_r,t9600,B2
    so.... B1 = FE and B2 = CA
    For this situation after sending FE CA, This PIC will receive FE CA for a 30 second, if done portb0. = high or if fail portb.1 = high.
    Which PIC are you going to use?
    What else this PIC will do in meantime?
    Oct 2007
    Im using PIC 16F84A,
    I think not do anything in the waiting time, just wait until 30 second.
    Will the 16F84A die one day?
    Ok, well, the only thing i could suggest, even if it really don't turn me on is to do a loop and use the Timeout feature of SERIN or SERIN2 or DEBUGIN. Almost the same thing we talked about in your previous thread...
    http://www.picbasic.co.uk/forum/showthread.php?t=7218
    except you don't need any PAUSE, SERIN will do it for you. Read the whole SERIN or SERIN2 or DEBUGIN sections of your manual.
    Oct 2007
    Ok...using the previous thread....but where want to paste this serin command...
    (Serin RX_r,t9600,B1)
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 04:47
  2. Data EEPROM gets clobbered during programming
    Last Post: - 18th July 2008, 02:46
  3. weird data
    By chriroz in forum mel PIC BASIC Pro
    Last Post: - 12th November 2006, 16:13
  4. Internal EEPROM Read/write Addressing Errors with 18F PIC's
    Last Post: - 12th July 2005, 19:42
  5. Sinus calculating !
    Last Post: - 28th November 2004, 23:56
