Mixing PortB interupts
Results 1 to 3 of 3
    Feb 2003
    Salt Lake City, Utah USA
    Smile
    Chris,
    PortB change interrupts usually refer to bits 4-7 only, which means you will be okay (from an excluding bit 0 point of view). What pic are you using?
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    Apr 2007
    Santiago, Chile
    Default PORT B interrupts
    I am using PIC16F877A but I donīt really want to use PORTB bits 6 & 7 as I like to use them for programming the PIC while powered up and plugged in.
    Is there another PIC which fits in the same range that has different interrupt or programming pins?
    Chris
  1. PICs can do more if use others than delays instructions
    By hardcore in forum mel PIC BASIC Pro
    Last Post: - 24th February 2010, 20:52
  2. MY FIRST scrolling 8X8 LED
    Last Post: - 15th August 2008, 17:23
  3. shifting problem
    By helmut in forum mel PIC BASIC Pro
    Last Post: - 31st August 2007, 07:11
  4. Output PIC module
    By freelancebee in forum mel PIC BASIC Pro
    Last Post: - 12th September 2005, 21:10
  5. Can anyone help a beginner in a struggle?
    By douglasjam in forum mel PIC BASIC
    Last Post: - 6th May 2005, 00:29
