About timing in pic basic pro
Results 1 to 3 of 3
    Oct 2007
    Question About timing in pic basic pro
    Dear all,
    My program :
    PortA.0 = input
    PortB.0 = Output 1
    PortB.0 = Output 2
    I want to check condition for the PortA.0
    If PortA.0 = high, PortB.0 will set high. ( PortA.0 will be check for 30 second only, if
    portA.0 still = low after 30 second PortB.1 will high.)
    some body can help me how to program for this situation.
    mmm, something is not clear in your explanation....
    When you said, "PORTA.0 will be check for 30 second only" once PORTA.0=1 on or once you put the power on your PIC?
    Let's say once your put the power on your pic...
            TRISA = 255
            TRISB = 0
            CounterA    VAR WORD
            PB          var PORTA.0
            OUT1        VAR PORTB.0
            OUT2        VAR PORTB.1
            PORTB = 0       ' Clear all leds
            CounterA = 0    ' Clear counter
    Start:
            while (CounterA<300) AND (PB=0)
                CounterA = CounterA + 1
                wend
            if CounterA>=300 then
                OUT2 = 1
                    OUT1 = 1
    Spin:   GOTO Spin
    Oct 2007
    Smile Thank you
    Dear mister_e,
    Thank you for your suggestion,
    I try follow your methode in my program,
  1. Looking at pic basic pro symbol values in mplab 8.15a simulator
    By ukemigrant in forum mel PIC BASIC Pro
    Last Post: - 16th May 2009, 13:18
  2. I want to buy PIC BASIC PRO...
    By simransingh in forum General
    Last Post: - 30th October 2007, 17:13
  3. PIC BASIC or PIC BASIC PRO
    By kirkmans in forum USB
    Last Post: - 20th April 2007, 00:52
  4. Replies: 5
    Last Post: - 17th January 2006, 19:26
  5. How to use 93C46 Type EEPROM using PIC Basic PRo
    By in forum mel PIC BASIC Pro
    Last Post: - 1st April 2003, 04:07
